Does any body know if there is any possibility I could use an exploder Gt40 intake on the stock 351W bottom with porting like the above did?
I am building a 351W stang that we are trying to not spend to much money on and the current issue is the clearance of the hood with the truck intake and don't want to cut the hood if possible. I have an entire 302 from an exploder that I am using the GT40P heads and a guy sold me custom shorty headers that clear the plugs really cheap.
Trav
The explorer intake will not fit on any truck lower. If you google explorer intake vs truck I take, you'll see a lot of comparison pics.
Explorer and gt40 have staggered ports. Truck 5liter, truck 351, and mustang 5liter, have inline ports.
Scroll up, look at my porting pics, get a 351 truck lower, and a Holley systemax upper, and you'll be fine. Might need a spacer but the systemax intake is pretty tall, I think it has plenty of clearance.
Or get a 302 truck upper, cut the plenum off, and fab up a box upper. I've done that a bunch of times.
Or buy the edelbrock knockoff intake on eBay. They are like 350-400 bucks.
You'll still need hood clearance. The 351 is taller by a bit. They fit in foxbodys better than the sn95. But you can get lowering engine mounts, and then I dropped my k-member, and used lowering springs (to get ride height back) and that dropped the engine into the car nicely, but still had to cut the stock hood on my 94gt.
the k member has been modified to sit lower then an aftermarket Kmember I just need like 3-6" of clearance then the hood will shut. Maybe I don't have a stock hood on it currently no idea. I don't usually work on cars but it is a project for my sister that we got for free.
Maybe I will revert back to the 302 from the explorer and use the 351 in one of the other trucks. Thanks guys.
Trav
I don't care about the flow the car is just going to be a DD in the summer and frankly a V8 stang is going to be plenty to not get my sister in trouble with the police. exhaust will be upgraded only cause it will be custom since the car was originally a I6.
Trav
And the gt40 and explorer intake flows less than the 302 truck intake...
Not questioning you're statement, but are there any flow tests, or seat-of-the pants comparison that can prove this claim? I've heard that Mustang guys sometimes prefer the truck set up over the Mustang one. Just wondering where you got the info. Thanks
Info come from a guy on this forum, who actually flow tested these intakes...
I take it you haven't actually seen each of these intakes beside each other?
When the 302 truck rectangular intake runner, is as wide as the gt40/explorer is in diameter, you can visualize which one has more potential.
Oh I was referring to a 5.0 GT40 upper & lower on a 5.8. As you put it above, the diagonal pattern is not going to with inline lower of the 5.8
No matter how you hog out the ports.
In other news... I still have unmolested parts of truck 5.0 intake lower, GT40 upper & lower so one day, I'd like to measure the volumes of all 3, just to see what they are.
