351w EFI performance upgrades?
Old Sep 12, 2016 | 09:33 PM
  #151
UNTAMND's Avatar
UNTAMND
That's only .014"... Not gonna hurt anything.
Old Sep 12, 2016 | 09:38 PM
  #152
351miller's Avatar
351miller
Thanks ready for 4 wheels grocery shopping on enduro is getting old
Old Sep 12, 2016 | 10:33 PM
  #153
UNTAMND's Avatar
UNTAMND
I'd have to go shopping every day!!! I eat a backpacks worth of food in a day man... That's gotta suck.
Old Sep 12, 2016 | 11:00 PM
  #154
GoinBoarding's Avatar
GoinBoarding
Just need to add a basket to the enduro! I'm hoping my trucks not down for more than a weekend when I swap in the new 351 in the coming weeks/month. All I have for alternative transit is a pedal bike, 100cc dirtbike, or snowmobile.
Old Sep 18, 2016 | 09:14 AM
  #155
351miller's Avatar
351miller
Motor is back in. Do I need to retorque heads after a couple heat cycles
Old Sep 18, 2016 | 10:37 AM
  #156
UNTAMND's Avatar
UNTAMND
Nope. Not usually. Some head gaskets recommend it, like mls and shim type gaskets, but stock style gaskets don't.
Old Sep 18, 2016 | 04:22 PM
  #157
'89F2urd's Avatar
'89F2urd
It's always a good idea to re torque after a heat cycle, but not necessary with a "material" gasket. It's 6 in one, half doz in the other...you could break it down and do a re torque just to find out nothing moved, or you might find that some were off torque spec. If you never tried, chances are you'd never know there was a difference...if you try, there's still a chance there is no difference......
Old Sep 18, 2016 | 05:48 PM
  #158
351miller's Avatar
351miller
Motor is running with short pipes on headers. Truck has no tach but when you get rpms up around 2500 that's a guess. Feels like fouled plug, exhaust cackles a little like when you let off. I haven't done timing bump yet and o2 isn't hooked up. Could the 02 cause this
Old Sep 18, 2016 | 06:01 PM
  #159
UNTAMND's Avatar
UNTAMND
Check firing order again.
Make sure plug wires are separated correctly. I've had a few plug wires cross arc even when new.
Gotta check timing. I only run 10*. My truck doesn't like more. It tends to have preignition.
O2 shouldn't do much, but should do something once warm.
Exhaust helps you to hear the noises.
Keep an ear on it all. Mess with it some and let us know how you make out.
Old Sep 19, 2016 | 05:19 PM
  #160
351miller's Avatar
351miller
Why would oil fill on drivers side be sucking air
Old Sep 19, 2016 | 05:55 PM
  #161
UNTAMND's Avatar
UNTAMND
Pcv valve not strong enough. It's basically a vacuum leak.
A heavier weighted pcv will take more vacuum to open. Not sure if a 460 pcv is different or not.
Just unhook it to see if it stops.
Unless it's an intake gasket leak...
Old Sep 19, 2016 | 06:42 PM
  #162
351miller's Avatar
351miller
It's sucking air around oil fill which fits tight no pvc in that cover
Old Sep 19, 2016 | 07:19 PM
  #163
GoinBoarding
Miller how did the ProComp heads look?
Old Sep 19, 2016 | 07:59 PM
  #164
UNTAMND's Avatar
UNTAMND
Pcv is in passenger side, but it's sucking vapors from pass side, but pulling vapors from valley and through right side valve cover breather.
How do you know it's sucking air from around it?
My truck has a hose fitting to go from filler tube out to the air box. It's designed to pull air (metered if it's maf) and suck fresh air into engine and pull vapors out the pass side pcv...
I'm not completely understanding what you mean.
Unhook pcv and block it off. If it stops sucking air, leave it unhooked. Add breathers.
If you unhook pcv and it's still sucking air in, then you may have a bad intake gasket and it's sucking air into a cylinder from inside the intake valley. You may be able to check the plugs and see oil residue on a plug sometimes.
  #165
351miller's Avatar
351miller
Ok to me but I don't know what to look for
