351w EFI performance upgrades?
Old Nov 28, 2016 | 03:14 AM
  #196
bentwire's Avatar
bentwire
need to get a timing light they are very cheap for the knowledge they provide
Old Dec 25, 2016 | 07:50 PM
  #197
bentwire's Avatar
bentwire
Originally Posted by andym
It makes absolutely no sense to upgrade the heads, exhaust, and intake and leave the factory cam in place.
depends on how you acquired the headers and intake not everyone is independently wealthy enough to buy things as needed some trade swap and get things given to them be careful to judge others a wide man makes no judgements period!
Old Dec 25, 2016 | 08:19 PM
  #198
Willigaf's Avatar
Willigaf
I'm kinda wide, AND judgmental at times.
Old Dec 26, 2016 | 09:39 AM
  #199
Conanski's Avatar
Conanski
Originally Posted by 351miller
Mods are pro comp gt40 heads, 1.7 roller rockers with longer pushrods to center on valve stems
Have you done a compression and leakdown test? From what I have read the valve seats in those Procomp heads leave a lot to be desired in terms of sealing with the valves, and the longer pushrods you used may be compounding the issue, a leakdown test will tell you if the valves are sealing or not and then you just have to figure out if you need to fix one or both of those things.
Old Oct 22, 2017 | 01:41 AM
  #200
Skip1970's Avatar
Skip1970
whats it gonna take if i wanted to tow 20k with a f350 and a 351w auto e4od
Old Oct 22, 2017 | 07:16 AM
  #201
UNTAMND's Avatar
UNTAMND
This is something you should start your own thread about. This is quite a topic, that can vary from getting a stroker kit, to just towing in low range.
Old Oct 22, 2017 | 07:20 AM
  #202
Willigaf's Avatar
Willigaf
Huge *****. All of the above noted mods or more. More gear in the axle. The best brake upgrade money can buy. A great big liability policy and a last will and testament.
If Miller is still around... Curious how the procomp heads are holding up...
Old Oct 22, 2017 | 07:41 AM
  #203
UNTAMND's Avatar
UNTAMND
I tow 20k with my 87 F250... but it's a manual 460 truck. It has stock brakes though. There aren't many upgrades available, so trailer brakes are very important.
Old Oct 22, 2017 | 07:44 AM
  #204
UNTAMND's Avatar
UNTAMND
If your truck has 350 gears, you're going to need an upgrade.
You're going to need to read this whole topic, there are a lot of ideas and tons of info that has everything to do with what you're asking. Lots of power upgrades for your truck.
Old Oct 22, 2017 | 11:34 AM
  #205
Lead Head's Avatar
Lead Head
A newer truck. That's way over the weight limit of even a diesel equipped truck from this era.
Old Oct 23, 2017 | 01:20 PM
  #206
andym's Avatar
andym
+1. The truck simply cannot do what you are asking. My 7.3L would struggle to pull that much.
Old Oct 25, 2017 | 10:43 PM
  #207
Skip1970's Avatar
Skip1970
imnot trying to break any land speed records, i just need to tow 70 miles 2 times a year that much, and im over estimating the weight a bit to be safer. i probably end up putting my idi diesel in it and a t18. its ot 410s and i wouldnt tow over 55mph anyhow
Old Oct 25, 2017 | 11:47 PM
  #208
Lead Head's Avatar
Lead Head
A 4-speed IDI with 4.10s would be absolutely hopeless trying to tow 20K.
Old Oct 25, 2017 | 11:55 PM
  #209
Skip1970's Avatar
Skip1970
thats crazy talk. i have several idi that are good haulers
Old Oct 26, 2017 | 12:27 AM
  #210
Lead Head's Avatar
Lead Head
I'm sorry but even a stock OBS 7.3 PSD is a dog with just 12k behind it. 20K behind an IDI would be a miserable experience.
