there's no better auto trans.however there are many builders who specialize in E40D's.
such as racerx,ats,bts.due to the power output,these trans are likely overkill for our applications.so should you ever need,it'll likely outlast the truck.not cheap though.i think bts (brains truck shop) is the only one who offers a lifetime warranty.likely the most expensive option though of course.
while installing gauges,put a trans temp on your list,and install an external aux cooler should you need it to aim for temps around 175 @ the test port or pan.
flush every 30k miles.though perhaps a bit over kill if you can maintain such temps,but fluid is cheap compared to transmissions.
Well i do know something most had happen to the trans in truck i have notice when i was under the trans had yellow marking on it like it came out bond yard just hope when they did they put new converter in it the trans fluid is nice red and hard see it on the dip stick
I think you were doing pretty good to get 65 with that load...
I think your problem is the tach or sensor, and not that you're really idling at 300 rpm. You could tell for sure if it was turning that slow. It would be shaking the truck apart.
