idle speed incresing
Old May 31, 2005 | 04:26 PM
dieself250's Avatar
dieself250
today i noticed my idle speed has gone up only when its hot, its up at 900rpms.
it cold idles at 850 for a few kicks down to 750. 20 mins later, i get to work and its at 900, what would cause this???????????????/
Old May 31, 2005 | 06:40 PM
351M's Avatar
351M
This is new, I have a bad tach that will say 300 rpm once in awhile, can you tell if the engine is idling noticably slower?
Old May 31, 2005 | 07:08 PM
dieself250's Avatar
dieself250
i can hear the diffrence between 750 and 900, it sounds like the cold idle never kicked off
Old May 31, 2005 | 08:05 PM
351M's Avatar
351M
Is the truck running fine otherwise? I would be wondering if the IP isn't on its way out.
Old May 31, 2005 | 09:05 PM
dieself250's Avatar
dieself250
it runs great no major problems with it i gone 3000 miles since last oil change and hasent consumed a drop, smokes very litte on startup and when i stand on it,
but i have began to wounder if it was the IP going
Old May 31, 2005 | 09:17 PM
Dieseldan7.3's Avatar
Dieseldan7.3
I have noticed my engine now idles at 900 when its warm out. used to idle at 800. I assume this is normal with temperature.?
Old May 31, 2005 | 09:52 PM
351M's Avatar
351M
So far thats the only thing I have really thought of, I'm sure there are others that could give you a better answer. It could also be getting air when it warms up but that usually makes it run a bit louder, idle rough or somthing similar.
Old Jun 3, 2005 | 09:47 AM
Gwlexoh's Avatar
Gwlexoh
high idle possibility
Have you considered your air conditioner?
When compressor starts, idle usually increases somewhat. Not sure how many RPMs.
Just a thought
Old Jun 3, 2005 | 04:17 PM
dieself250's Avatar
dieself250
it doesnt have A/C, but i think it is the IP acting up cause now its being a pain to start when its cold
Old Jun 3, 2005 | 10:17 PM
351M's Avatar
351M
Check the glow plugs, and see if any of the injectors are wet around the return line, as well as for any other possible air leaks before sayint the IP is causing the hard starting, then if no other probs are found we can get back to that one.
Old Jun 4, 2005 | 01:33 AM
dieself250's Avatar
dieself250
i just replaced ths glow plugs, the entire fuel system is dry except for that pressure sending unit thing on the fuel filter housing has a little leakage i am jona replace the lift pump tommarow and wile im at it jona check all the injectors, i have notaced the high idle is not dependet on tempature 40 - 70 makes no diffrence
Old Jun 7, 2005 | 07:40 PM
seb250's Avatar
seb250
HI, this could be, air filter, try to mantein clean.
Old Jun 7, 2005 | 09:43 PM
PLC7.3's Avatar
PLC7.3
Visit this web page and look for Filter/housing air leaks.........scroll down to IDI
http://www.intellidog.com/dieselmann/home.html
Old Jun 7, 2005 | 11:06 PM
dieself250's Avatar
dieself250
Thanks that site is very usefull , i do have a few fuel leaks on the housing, next step check for air in lines and fix the leaks
brandon.edwards
Jan 19, 2013 05:44 PM
97ranger xlt
1983 - 2012 Ranger & B-Series
Oct 13, 2011 09:51 AM
itcowboy
Modular V10 (6.8l)
Dec 8, 2007 06:55 PM
M.Ghost
1997 - 2003 F150
Jan 28, 2007 09:36 AM
dan66tampa
20
Feb 28, 2005 09:34 AM
