What is the best engine assembly lube
I have put together a couple of gassers and am in the process of rebuilding my 7.3 idi turbo. On the gassers I used stp on the bearings and coated the cylinder walls with oil and give the pistons a coat of oil before putting them in the block. Is there any difference when assembling diesels.
on
I don't think it makes any difference gas vs. diesel. I use trans fluid on the cylinders and regular motor oil on the bearings, unless the engine is going to sit a while before first fire-up, then I use vasoline on the bearings and squirt some fresh ATF in the cylinders before firing (spin the motor over with the spark plugs/injectors out when doing this).
Mix of 10-w-40 and STP. Dip the pistons in it before putting them in the cylinders. Just assembled my 6.9 and installed it. What I did to ensure good oiling was to take out the oil pressure sender from the back of the block, put a 1/8 NPT nipple in it, a rubber hose to that, and a funnel hung from the hood attached to the rubber hose. I dumped a mix of 10-w-40 and STP down the funnel while I worked on other things. That ensured all the oil passages, oil cooler, etc. were full. It took a long time, like several hours, because it was gravity flow and thick because of the cold and STP. But, on first crank, it came right up to 30 psi immediately.
caterpillar
10-22-2006 07:19 PM
71LTD390
20
05-27-2004 03:09 AM
