Project.....? I need a nickname!
Old Dec 19, 2011 | 05:36 PM
FourxFour84's Avatar
FourxFour84
Hey guys, I'm newer around here and have found this forum to be extremely useful. I've had my 84 4x4 for a little over a year now and have done a decent amount of work to it. Tonight started the biggest of them all......an engine swap. My tired 351w (218k) was burning a quart of oil about every 3 days. But i found a rebuilt 302 out of a 85 mustang and for the price i couldn't resist. I want to document what I am doing to the ol girl and get some feedback from you guys! Hopefully when it is all said and done she'll have a nickname finally. I'll post some pics of my progress tonight after i get all washed up.
Old Dec 19, 2011 | 05:54 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Don't name it, til you drive it.....
Learn it's quirks, issues, and personality....
Mine is named Michelle, because it acts like a 19yr old drama queen of a teenager.....It is literally always something...
My 1994 was Ethel....It had the personality of a 45 yr old woman, that never needed anything, but simple maintenance.....
Trust me, when the time comes, you'll know it...
Btw, WELCOME TO FTE!!!......we're glad to have ya......If ya have some pics to put up, use photo bucket, and then either copy/paste the pic to the entry, or use the image code...
Old Dec 20, 2011 | 04:39 PM
FourxFour84
got some pics coming up! enjoy!
Old Dec 20, 2011 | 04:41 PM
FourxFour84
I guess like any good story it should start from the beginning......
thats how i first bought her for $500 minus the tires. had a bad timing chain and a busted rocker arm, among a million other issues, banged up body parts and such.
this is her after a new fender and door
Old Dec 20, 2011 | 04:49 PM
SideWinder4.9l
Lookin' good!...I like that wheel/tire combo......
FOr some odd reason, the name Shirley comes to mind, when I look at that truck..
Old Dec 20, 2011 | 05:39 PM
FourxFour84
Shirley is a good redhead name.....i like it! I like that wheel/tire combo as well but it is not what will finally be on it. I'll post pics of those tomorrow
Here is how she sat as of last week after the body lift was put on....
and here are some pics of my progress of last night and today
sprayed it all down with degreaser, letting it dry overnight and painting first thing in the morning
found a broken motor mount explains why the motor had some movement to it. new ones will be in tomorrow
Old Dec 20, 2011 | 06:14 PM
00Boss's Avatar
00Boss
Very good lookin truck. I see loads of potential with it. And the white wheels look good on it to.
Old Dec 20, 2011 | 07:29 PM
FourxFour84
thanks!
Old Dec 21, 2011 | 10:31 AM
FourxFour84
just finished degreasing and scrubbing the engine bay.....paint in the next hour and hopefully the engine in by sundown! more pics to come
Old Dec 21, 2011 | 11:24 AM
Gary Lewis's Avatar
Gary Lewis
Not that it matters since you have a different engine, but I don't think that one is original to the truck. Or, at least that head isn't. That's because that's a rail-rocker that's broken, I think. It certainly isn't the stamped rockers that should have come on the truck originally. Rail rockers came on a short run of heads in the late 70's IIRC, and I know they were on the D7 heads I used for a while. There are several reasons Ford used them only briefly, and you are looking at one of them.
Old Dec 21, 2011 | 01:45 PM
FourxFour84
You are correct Gary. I ran the VIN when i first bought it and she originally was a 302/4 speed truck. I've been trying to pull the numbers off the block to try and identify its origin but it has so much crud on it all i could make out was the first number.....a 0. So my guess is 80? I have a few pics coming soon along with some questions, hopefully you guys can help me out
Old Dec 21, 2011 | 04:52 PM
FourxFour84
hey guys, it rained most of today :/ so i spent the day organizing everything and switching accessories from the 351 to the 302. I ran into a few problems along the way though, maybe you guys could help!
I ran into this thing that runs all the way to the fuel tank but was not connected to anything in the engine compartment, can i remove this?
this is the back of the 302....the back of the 351 is bigger, is there a way to remove the inner bearing? i believe the mustang it came out of was a manual transmission.
this is the back of the 351
and as promised here is a small preview of the new wheels and tires
Old Dec 21, 2011 | 06:10 PM
Gary Lewis's Avatar
Gary Lewis
The thing in the first picture is the canister that captures vapors from both the gas tank as well as the carb. There should be the small line back to the tank(s) and a large one to the vent on the carb.
As for the pilot bearing in the crank, I've pulled them out with a seal remover and even the head of a nail that was locked in vice grips. And, I've read about guys getting them out by putting a lot of grease in, then a shaft that just fits in the bearing, and hitting that with a hammer. That causes pressure on the back of the bearing and drives it out.
Old Dec 21, 2011 | 08:14 PM
ctubutis's Avatar
ctubutis
I am no expert and am not aware of all the variations, but every emissions label I've seen (where I've looked for this stuff) shows one charcoal canister per gas tank.
IIRC there should also be some sort of solenoid & check valve to direct the fumes into the engine for burning upon engine start-up.
In any event, yes, it's part of the EVAP (Evaporative Emissions) system and is good to have to keep the truck from smelling like gasoline as well as being good for the environment.
Old Dec 21, 2011 | 11:18 PM
FourxFour84
alrighty! thanks guys! your help is much appreciated
