Project.....? I need a nickname!
Old Jan 30, 2012 | 06:07 PM
  #106
FourxFour84's Avatar
FourxFour84
I'm sorry i thought i threw the word "like" in there, my bad. But yes the engine stops running when i let go of the key. If i hold the key it will keep running but grinds the starter, I only did that briefly to experiment. And yes I have a test light.
Old Jan 30, 2012 | 06:46 PM
  #107
ctubutis's Avatar
ctubutis
OK.
First, let me ask... your starter solenoid has two fat cables (one to battery, one to starter) and how many small wires connected to protruding-screw terminals? One or two? I hope one.
I don't know what wire(s) burned up and what you replaced, but we need to do some checking of things.
This system provides full battery voltage to the coil in START and drops it to around half that while in RUN. Sounds to me like the START stuff is working, but not in RUN.
See if you have power at the ignition module (on the driver's side wheel cover). Battery voltage to the red wire in RUN and to the white wire in START.
I'm betting you have voltage in the white at start (the engine starts ) but let's see what happens in RUN.
If you have power to the ignition module in RUN, then go see if you have power to the coil + terminal in RUN (you should have battery voltage here in START).
Old Jan 30, 2012 | 07:05 PM
  #108
ctubutis's Avatar
ctubutis
BTW I'm sorry, Gary, I don't mean to intrude on your diagnostic work here.
Old Jan 30, 2012 | 07:10 PM
  #109
Gary Lewis's Avatar
Gary Lewis
Hey, no prob. I've grilled a filet and am enjoying an evening with my wife. You are doing good.
Old Jan 30, 2012 | 07:13 PM
  #110
ctubutis's Avatar
ctubutis
I just read back some to try and figure out what wire he's talking about.
Seems he has an MSD ignition ignition with a wire from the box to the starter solenoid.
I don't know squat about an MSD thinger, but I'm going to assume it's a plug-in replacement for the DS2 stuff.
Old Jan 30, 2012 | 08:27 PM
  #111
bruno2's Avatar
bruno2
Kind of sorta Chris. The box has to be powered to a constant 12 volts and then full time grounded as well. The box then supplies the power and ground to the coil and the factory wires providing that are no longer needed. Of course the box is wired into the dizzy and there should have been a wire with a square connector that has a 1/4" spade terminal hiding in it from the factory grouped in the harness that had the coil connections as well as the oil pressure and water temp gauge wiring that will supply a key on 12 volts to the box so that it comes on when the key is put into the run position.
Last edited by ctubutis; Jan 30, 2012 at 08:58 PM. Reason: Fixed spelling of spade (at least, that's what I think it's supposed to be)
  #112
FourxFour84
I have two smaller ones, the one wire was the one that burnt up and i replaced the whole wire.....the other smaller one has a wire with a rubber boot that plugs into it.......and yes the MSD box was spliced into where the DSII would be. I found so looseish connections and fixed them but to no avail. The truck refuses to stay running, i will go ahead and try some of your suggested tests tomorrow. You guys are great btw! Very thankful.
Old Jan 30, 2012 | 09:05 PM
  #113
ctubutis's Avatar
ctubutis
The "old" factory way of using two small wires on the solenoid:
Red/blue-stripe - connected to S terminal, provides battery voltage to solenoid when key is in START, activates the solenoid and sends power to the starter motor. You will always have this wire, the other end is at the ignition switch (with possibly a NSS (Neutral Safety Switch) or clutch switch in between).
I forget the color of the other wire, but it goes on the I terminal on the solenoid. When the solenoid has been activated (by the red/blue wire described above), the solenoid sends battery voltage to that wire, the other end leads to the coil positive. This gives the coil full battery voltage in START. Ford later moved that function to elsewhere in the wiring.
I have no idea what MSD does; other guys here might, and/or they may have a Tech Support section on their Web site.
Thanks for chiming in, Bruno.
Old Jan 30, 2012 | 09:10 PM
  #114
FourxFour84
The truck was originally a 4 speed, so it makes sense for that other wire to be there I suppose.
Old Jan 30, 2012 | 09:19 PM
  #115
bruno2's Avatar
bruno2
Today at 08:58 PM. Reason: Fixed spelling of spade (at least, that's what I think it's supposed to be)
Thanks for fixing that Chris! I was plowing through that post b/c I had a big plate of stir fry in front of me. I usually post and then proof read to edit whatever mistakes have been made. However, I was looking for a post that I had here(probably in the what have you done to your truck thread) where I believe Jim or Jeremy maybe even Franklin posted a link to the MSD diagrams for the trucks we are discussing. I wasnt successful at finding it, but , it's out there somewhere. I still think it's in the thread I mentioned somewhere around the first week or two of December.
Old Jan 30, 2012 | 09:23 PM
  #116
FourxFour84
Thanks I'm searching for it now!
Old Jan 30, 2012 | 09:24 PM
  #117
ctubutis's Avatar
ctubutis
*sigh* Stuffing your face again.........
Yeah, I saw that, I think it was by Jim (ArdWrknTrk). Lemme see if I can find it, or I'll just ping him.....
BTW Bruno, nice pix you've been posting.
Old Jan 30, 2012 | 09:26 PM
  #118
ctubutis's Avatar
ctubutis
This one, I think:
Ford Truck Enthusiasts Forums - View Single Post - '86 4.9L Carb/Dist. Conversion to DSII
Old Jan 30, 2012 | 09:35 PM
  #119
FourxFour84
Well heck....that just made life alot easier hahaha, thank you!
Oh by the way, my name's Kyle....no need to use my username anymore!
Old Jan 30, 2012 | 09:51 PM
  #120
bruno2's Avatar
bruno2
I can sometimes transport them from elsewhere. Sometimes when I am finished the link ends up with a dead end too. Like the FSB link I posted that you had to fix to get it to work. I cant take a pic with a phone or camera and link it up though. I had my buddy try and he is very tech savvy , but , couldnt get it done here or at FSB. He has done it on other sites with lots of luck for me, but , for some reason not here.
