Project.....? I need a nickname!
Old Jan 26, 2012 | 08:08 PM
  #91
bruno2's Avatar
bruno2
If you dont have a timing light you can use a vacuum gauge to set the timing. Try to get it to pull about 18 inchlbs at idle.
Old Jan 26, 2012 | 08:28 PM
  #92
FourxFour84's Avatar
FourxFour84
I have a timing light, I'm going to fiddle with it come Monday, supposed to be about 40 degrees again. I'm going to replace that wire and then triple check EVERYTHING. I will keep you guys posted. Thank you again
Old Jan 26, 2012 | 08:45 PM
  #93
1983F1503004x4's Avatar
1983F1503004x4
When timing with a vacuum gauge, you don't aim for a specific number like timing with a timing light.
Timing with a vacuum gauge, advance or retard the distributor to achieve the highest vacuum reading in Hg possible. This could be anywhere between 16 to 24 inches of vacuum. Then, once you've reached the vacuum as high as it'll go, retard the timing by 2 inches of Hg (Hg is the periodic name for Mercury) and lock the distributor down.
Then, go take her for a test drive! If she pings or acts up when going up a hill or under heavy acceleration, retard the timing a SLIGHT amount then take it for a test drive. If it doesn't ping, you're set.
Typically, on stock motors you want to time with a timing light. The vast majority of people who build motors typically time with a timing light too, but from what I've heard, a vacuum gauge is the best way to tune a motor, both with ignition timing and fuel/air mixture.
I use a vacuum gauge when tuning carburetors. It's the only way to go IMO.
Old Jan 30, 2012 | 01:30 PM
  #94
FourxFour84
Hey all, Just a quick update. I replaced the burnt up wire. I had a spare Starter Solenoid so i replaced that just in case. Now I have run into another problem......the truck starts for about 2 seconds while i have the key turned, but the second i let go of the key it shuts off. It loses ALL power when i let go of the key. I'm a tad confused.....maybe a fuse? Any input would be wonderful. Thank you gents!
Old Jan 30, 2012 | 01:37 PM
  #95
Gary Lewis's Avatar
Gary Lewis
At first I thought it was the ballast resistor that drops the voltage when in Run that is causing the engine to die. But, you say you lose all power, and that sounds like an ignition switch problem. There have been a lot of instances of that due to the age of these trucks, so you should easily be able to find some threads about that by doing a search.
Old Jan 30, 2012 | 01:41 PM
  #96
FourxFour84
Thank you, I'll check the ballast resistor and the ignition switch. You guys are always great help. Thank you.
Old Jan 30, 2012 | 01:47 PM
  #97
Gary Lewis's Avatar
Gary Lewis
I didn't really finish the thought about the ballast resistor, and maybe should. During starting your coil should have battery voltage to it. But, when you release the switch and it goes back to Run the voltage is supposed to go to about 1/2 of battery voltage to keep from burning the ignition up. So, if it is just the ignition that is losing power then that circuit is highly likely to be the culprit. It could be a burned ballast resistor, a wire burned into, or even a connection that got left off.
But, if the whole truck loses power then the ignition switch if probably the culprit.
Old Jan 30, 2012 | 02:10 PM
  #98
FourxFour84
OK so i checked to see if it was the ignition switch....it would appear not, with the key in the RUN position all my lights and stuff work. So i guess the ballast resistor? Or maybe something is loose.....holy moly this is why i strongly dislike wiring stuff. Thank you again Gary.
Old Jan 30, 2012 | 04:07 PM
  #99
ctubutis's Avatar
ctubutis
4x484 (why did you choose such a confusing nick? j/k ), are you sure you have your wires connected to the solenoid correctly? IOW there are some wires that attach to the *battery* side of the solenoid (not the starter-motor side) these wires supply power to the rest of the truck.
You say you lose all power when you release the key from START and let it spring back to RUN, does that include the dome light & headlights, too?
Old Jan 30, 2012 | 04:15 PM
  #100
FourxFour84
Well, I don't have a domelight and the the headlights are currently disconnected. What I did notice is that when I turn the key to the ON position the "Fasten Seatbelt" light no longer comes on. And I reconnected the solenoid exactly as i disconnected it, i made sure of this by doing each wire one at a time.
Old Jan 30, 2012 | 04:51 PM
  #101
ctubutis's Avatar
ctubutis
What about things like the wipers, radio & fan?
It sounds to me like a blown fusible link if you are certain you have all the wires correctly hooked up.
Old Jan 30, 2012 | 05:00 PM
  #102
FourxFour84
wipers work, radio is out, fan works, hazards work, brake lights work.
Old Jan 30, 2012 | 05:23 PM
  #103
ctubutis's Avatar
ctubutis
What I'm trying to ask is if you have power to any of those devices with the key in RUN.
Old Jan 30, 2012 | 05:28 PM
  #104
FourxFour84
Yes, they all work when the key is in run.
Old Jan 30, 2012 | 05:51 PM
  #105
ctubutis's Avatar
ctubutis
OK, good.
Now, can you please clarify this statement:
Are you trying to say only that the engine stops running when you release the key from START?
Or, are you saying the entire electrical system loses power (which is what I think of when you describe losing ALL power)?
Do you have a voltmeter or test light?
