Throttle hook-up
Oct 27, 2011 | 12:19 PM
Throttle hook-up
How do i hook up the throttle cable to a elderbrok carb with a offy dp intake do i need a throttle bracket or is it direct hook-up?
Oct 27, 2011 | 12:48 PM
You'll need to rig up or purchase an aftermarket throttle cable bracket. The stock throttle cable bracket bolts to the stock intake, so it goes with it when it's removed.
Lokar makes one, I think it's the SRK-4000.
Oct 28, 2011 | 11:59 AM
The Lokar is a sweet piece.
Oct 29, 2011 | 01:23 AM
I use the Lokar too. Along with it you'll need the little bracket that holds the cable at the corner of the carb. SRK 4000, Summit Racing.com
Of course it would be less expensive to run a coat hanger through the firewall for a throttle cable.
Nov 2, 2011 | 01:03 PM
throttle cable
Now with the lokar bracket can I use my stock throttle cable to hook everything up?
Nov 2, 2011 | 02:48 PM
I don't think so but I'm not sure. I think some have used the cable from an Evan. I used the Lokar bracket and a 4' Lokar cable.
Nov 2, 2011 | 03:13 PM
part number
Do you have the part number for the cable.
Nov 2, 2011 | 05:26 PM
Nov 7, 2011 | 09:39 AM
Autozone also has a universal throttle cable and throttle cable bracket that works really good. They also have a the return spring kit and bracket.
Nov 16, 2011 | 12:13 PM
Throttle Cable
How long of a cable do i need to reach the carb
F-250 restorer
16
Jun 23, 2019 12:39 PM
ladelld33
Aug 16, 2009 06:56 PM
400miller
Jun 6, 2003 11:02 PM
olddawg
Jun 13, 2002 02:21 AM
2004 ,
23 ,
289 ,
360 ,
86 ,
cable ,
engine ,
f150 ,
ford ,
hook ,
hookup ,
lokar ,
ook ,
straight ,
throttle
