Edelbrock throttle linkage
Old Jun 6, 2003 | 09:59 PM
400miller's Avatar
400miller
How do you connect the throttle cable to the carb? I keep getting the cable in the way of the the kickdown and the hole is to big on the carb. I tried to put washers on each side of it but then my bolt is to short. I'm using a Lokar cable and bracket. Has any one connected it on a different place on the carb? Is there a special connector to fit the edelbrock carb where the throttle cable hooks up?
Old Jun 6, 2003 | 11:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
You might check with Edelbrock. They make a Ford throttle cable plate kit to align the stock cable bracket with the throttle arm. It also requires a number 1483 throttle lever adapter.
The kits list out as:
302 == #1490
351W == #1491
351M/400 == #1493
429/460 == #1495
