Electric fuel pump conversion
Old Sep 28, 2011 | 12:16 PM
Splatts's Avatar
Splatts
Anyone installed the electric fuel pump conversion kit from dieselsite.com?? Looking for the install guide and parts list for it.
Old Sep 28, 2011 | 12:22 PM
Splatts's Avatar
Splatts
Just the install guide would be great
Old Sep 28, 2011 | 12:48 PM
Splatts's Avatar
Splatts
I believe its the CPR fuel system
Old Sep 28, 2011 | 12:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Doesnt the system comes with instructions?
http://www.dieselsite.com/pdffiles/DPJan2010OBSCPR.pdf
Old Sep 28, 2011 | 01:11 PM
Splatts's Avatar
Splatts
Ya but I am being a cheap ***. $1200 for the kit is steep. Just lost my fuel pump
The other day and looking to save some $$ with the conversion to an electric fuel pump.
Old Sep 28, 2011 | 02:02 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
To save money you should replace your fuel pump with a stock fuel pump. You can build your own electric fuel system for about half of the kit you mentioned. Others have done it here on FTE.
Old Sep 28, 2011 | 02:10 PM
Splatts's Avatar
Splatts
That's what I want to do is built my own. But I ain't no master mechanic or nothing. So I was goin to get all te parts myself and use the install guide as a reference to install it
Old Sep 28, 2011 | 08:00 PM
fordpride's Avatar
fordpride
here ya go
Electric fuel system conversion - PowerStrokeNation
Old Sep 28, 2011 | 09:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You want more info
Electric Fuel Conversion - Page 6 - PowerStrokeNation
https://www.ford-trucks.com/forums/8...onversion.html
Old Oct 2, 2011 | 07:09 AM
Splatts's Avatar
Splatts
Got the fuel bowl out the Fpr out and the turbo is putting up a pretty good fight! When I get that turbo out what are some things I should do. I noticed a bit of oil behind the turbo on what I believe it the ebfv. Probably the O rings in the actuator. I saw another guy had the same issue. Any other words of advice?
Old Oct 2, 2011 | 07:26 AM
427 fordman's Avatar
427 fordman
I'd eliminate the ebpv if I were you. Make sure you get new orings for the turbo and pedestal for when you reinstall it. Here are some ways to work with the ebpv. I did what gobstopper did. Clay also sells a pedestal with the ebpv deleted on it. My tymar dp came with instructions how to remove the flapper out of the turbo exhaust. Basically just drill out a couple rivets and a freeze plug is needed iirc.
https://www.ford-trucks.com/forums/9...pv+rod+removal
Old Oct 2, 2011 | 08:20 AM
Splatts's Avatar
Splatts
If u don't need it then why is it there? What r the benefits
Of removing it?? My old Fpr was nasty!!!
Old Oct 2, 2011 | 08:30 AM
427 fordman
It is just for faster warmup in cold weather. It does nothing else unless you'd wire it up for an exhaust brake. It does restrict air, maybe not a lot when its open, but it does. Removing it will allow for better exhaust flow.
Old Oct 2, 2011 | 09:51 AM
Splatts's Avatar
Splatts
So I can totally remove it from the turbo pedestal and gut the flapper dealeo. The fuel pump sits right in the front of the turbo almost under the pedestal? What's the big silver thing infront of that, hpop?
Old Oct 2, 2011 | 10:24 AM
427 fordman
Yes you can totally remove it from both places, that is what I did. You are right on the fuel pump and the hpop. The resevoir for the hpop is on top of it.
