Not Doin to bad on costs either. $800 including 3" DP and 3"to 3 1/2" cat delete pipe. 2 fuel pressure gauges pressed SS braided Teflon fuel lines, new boots all around the turbo ebpv delete and all the stuff for the electric conversion.
Ain't no one butt hurt brother. Sometimes when u don't exactly know what ur doin u get the tool made for the job. In hopes of not screwing things up. . Getting my fuel lines tomorrow…. I hope!!!
Very good deal IMHO.
Originally Posted by Splatts
I filled the hole from the stock fuel pump with a 7/8 freeze plug from napa. Got a freeze plug installer on line for like $50.
I sure hope that 1/32 of an inch done screw me. On a lot of other write ups where they used a freeze plug I only saw 7/8. Thanks for the info. Should I change it out??? I have a feeling doin so will be a big pain in the A$$. What would u fellas do. I haven't read anything on a 7/8 failing to do the job so…. Looks like Monday getting fuel lines. Got wiring to do today.
Man it was nice to see this!!!!! Had to swap a few fittings on the FPR, and for the feed to the rear of the heads I used a -4an compression fitting to connect the SS braided to an existing piece of fuel line. I was goin to change the rear fittings but the driversside in looked like a big pain to do so that is the route I went. Hopefully be firing it up by Monday!!!!!
