Electric fuel pump conversion
Old Nov 9, 2011 | 11:04 AM
  #61
Splatts's Avatar
Splatts
It's the two holes infront on the fuel pump bolt holes.
Old Nov 9, 2011 | 11:15 AM
  #62
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by Splatts
<a href="http://s1083.photobucket.com/albums/j390/Linetrash/?action=view&current=5e1819fe.jpg" target="_blank"><img src="http://i1083.photobucket.com/albums/j390/Linetrash/5e1819fe.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
My Fpr and Y fitting ready for install. On the Y fitting is a sender for a digital fuel pressure gauge in the cab.
I suppose you made the brackets, right? do you have more pics of them, and did you plug the hole for the stock fuel pump or what?
Where did you get the parts, specifically the Y part and the sender unit?
Old Nov 9, 2011 | 11:33 AM
  #63
Splatts's Avatar
Splatts
The sender came With the gauge that I got. The gauge is a glowshift blue digital fuel pressure gauge. Google it. Then the Y fitting I got from summit racing. In the search bar just type Y block. I can get u part #'s if u want but this way u can look around and see what u want. Double and triple check what size and type of fittings u are goin to use. I had to return a few things😜
Old Nov 9, 2011 | 11:36 AM
  #64
Splatts's Avatar
Splatts
The brackets we just some scrap stuff I found laying around. It's just 2 pieces a
Flat piece to go across to each bolt hole on the motor and the alluminum L bracket bolted to it. Drill a few holes and there u have it.
Old Nov 9, 2011 | 11:41 AM
  #65
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Thank you very much my friend And yes Id like to have the part #s please.
Old Nov 9, 2011 | 11:51 AM
  #66
Splatts's Avatar
Splatts
<a href="http://s1083.photobucket.com/albums/j390/Linetrash/?action=view&current=705b305d.jpg" target="_blank"><img src="http://i1083.photobucket.com/albums/j390/Linetrash/705b305d.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1083.photobucket.com/albums/j390/Linetrash/?action=view&current=986291f5.jpg" target="_blank"><img src="http://i1083.photobucket.com/albums/j390/Linetrash/986291f5.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
The L bracket is actually 2 pieces. (just what was laying around). It can also be bent at the angle I wanted.
Old Nov 9, 2011 | 12:00 PM
  #67
Splatts's Avatar
Splatts
Old Nov 9, 2011 | 12:03 PM
  #68
Splatts's Avatar
Splatts
The y block I got has the two holes in the back are 3/8 npt to -4 an fittings and the front is 3/8 npt to -6an fitting
Old Nov 9, 2011 | 12:14 PM
  #69
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
WOW, very good pics and thanks again for the info mi AMIGO.
Keep posting.
Old Nov 9, 2011 | 12:22 PM
  #70
tshrager's Avatar
tshrager
Did you get the fuel filter, housing, pump and water/fuel separator all from cat?
Old Nov 9, 2011 | 12:30 PM
  #71
Splatts's Avatar
Splatts
Yes I got them from cat. U can find them online too. I think i got the filters for $40 and the heads @ napa for $80 got to grind a little on the water fuel seperator filter head to make the cat filter fit right. I am swapping my fuel pump to an Airtex e2000 $85 amazon More psi and gph. I believe it's the oem replacement for the newer psd.
Old Nov 9, 2011 | 12:33 PM
  #72
Splatts's Avatar
Splatts
By the way I only got the filters from cat. The filterheads there were pricey. The fuel pump I got is on sale right now and when I ordered mine it said there was only a few left. FYI
Old Nov 9, 2011 | 12:49 PM
  #73
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Keep posting.
BTW, reps sent to you.
Old Nov 9, 2011 | 02:26 PM
  #74
tshrager's Avatar
tshrager
Good deal. Thanks for the info. I'll rep you when I get to my computer
Old Nov 9, 2011 | 03:11 PM
  #75
Splatts's Avatar
Splatts
<a href="http://s1083.photobucket.com/albums/j390/Linetrash/?action=view&current=0777d7c0.jpg" target="_blank"><img src="http://i1083.photobucket.com/albums/j390/Linetrash/0777d7c0.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
This is most of the stiff just set in there not bolted and no fuel lines ran
<a href="http://s1083.photobucket.com/albums/j390/Linetrash/?action=view&current=fa8fbb9e.jpg" target="_blank"><img src="http://i1083.photobucket.com/albums/j390/Linetrash/fa8fbb9e.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Tucks in there pretty nice.
