Project: Tow Tool
Old Sep 15, 2011 | 10:25 PM
dustybumpers's Avatar
dustybumpers
nice job.
make sure you have vented fuel caps on that truck, or it will create a vacuum and do what you describe. The caps for that don't screw in, they twist in. screw in caps are for the efi's. I had that problem with a box truck I bought used years ago, and someone had changed the caps when they put the body on it.
Old Sep 18, 2011 | 07:27 AM
hadfield4wd's Avatar
hadfield4wd
Good call. I'll make sure I have the right ones.
Old Sep 18, 2011 | 08:56 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hmmm,
I have screw in caps from the factory on my carbureted 460 with a mechanical fuel pump.
I know they hold pressure, because they are tested every year at the emissions station.
I don't know if they are one way to eliminate a chance of vacuum.
When I had to replace them last year I used the Motorcraft FC 920 caps from Amazon. They were on sale for about $10
Old Sep 18, 2011 | 12:12 PM
hadfield4wd
Well my whole tank is vented. So I'm not super worried about it.
Old Sep 18, 2011 | 01:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So have you figured out what is causing the fuel transfer?
Old Sep 18, 2011 | 02:15 PM
hadfield4wd
Not yet. It only does it for a couple gallons. Which is only an issue when both tanks are full. I'm going to pull the valve and clean it. There is a check valve in the switch that should prevent this. If that doesn't work then I'll get the place where I bought it to see if they'll replace it.
Old Sep 22, 2011 | 04:26 PM
hadfield4wd
So I got it running fairly good. Carb is right. I recurved the Duraspark II. That's helped with getting it going. It still hesitates when I come off idle. Not alot and the recurving and some carb tuning has helped it, but it still does it. Once it's off of idles it runs great. It also happens if I'm coasting in a gear then put it on the floor, hesitates then runs like a raped ape.
The last thing is the vacuum advance. Could this not functioning cause a hesitation? How do I test and set this thing?
Old Sep 22, 2011 | 04:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can test it, but I would suggest you check into your accelerator pump adjustment and shot.
There are different orifices and cams in addition to the pump arm adjustment.
Check the timing with the vacuum disconnected and plugged.
Then connect it to full manifold vacuum and see how much difference there is.
Here are the full instructions for adjusting the old Crane 99607-1 kit.
http://www.jegs.com/InstallationInst...70-99607-1.pdf
The tuning section begins at the end of page 3.
Hope this helps.
Old Sep 22, 2011 | 04:54 PM
Sw1tchfoot's Avatar
Sw1tchfoot
My old 4180 had severe hesitation that I never got fixed before replacing the carb. Upgrading to a #31 accelerator pump discharge nozzle helped but did not fix the problem. For a 460 you could probably skip to one of the next sizes up. (Stock size is #28) I never messed with the pump cams, but I know there is improvement to be made.
If the vacuum advance is really slow to react then I can see how it's possible to cause a slight hesition. Maybe look at your vacuum diagram too and see if you have it connected the same way as the factory had it.
Old Sep 27, 2011 | 03:46 PM
hadfield4wd
I got a #31 acc pump also got #64 main jets. Stock was #61.
Also after some testing the diaphragm is bad for the vacuum assist so I'm getting one of those to put on as well. Every little thing I do helps so we'll see.
Old Oct 3, 2011 | 11:00 AM
hadfield4wd
Well long story I went over everything and realized I had some things messed up. Mainly I had a vacuum line off the manifold going into the carb. I was told it was for choke pulloff on the EGR carb. Nope it isn't. It is for EGR and should be vented to the charcoal canister. So I did that. Now I don't have the vacuum leak. Stupid.
I also rejetted form #61 to #64 jets. And went from a #28 Acc pump to #31 acc pump. I will be getting a new power valve as well. I have a 6.5. I need a 8.5. Sizing is based on half of manifold vacuum. My manifold vacuum is 17. The 6.5 won't start to open until 13 (double the rated value). As a result the manifold vacuum has to get to 13 before it adds fuel. So that could lead to some power loss as well.
Old Oct 12, 2011 | 04:59 AM
hadfield4wd
So my plugs were fouled so I changed them and rejetted down 2 sizes from the #64 to the #62. As a result I had to go through the idle circuit again, set up floats etc etc. Also while I had it off I made a block off plate for my EGR. For all I know the valve was leaking and exhaust was getting into the intake.
There is still a slight hesitation but it's easy to drive around. So I'm calling the motor done (for now). I need to put in my brake controller and continue to change out filters until all the crud is out of the tanks.
Also had to put a heater core in so I changed the hoses going to the heater core as well.
Now I'll be slowly doing the cosmetic stuff.
Old Oct 12, 2011 | 05:11 AM
  #28
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Did you fix your vacuum advance?
Mine is out and causing all the symptoms you mentioned.
(Amazon shipped within 2 hours of placing my order )
You need to understand how, and why, Holley's power valves work.
A wideband O2 sensor can help in tuning if you don't care for their simplified instructions.
Old Oct 12, 2011 | 09:50 AM
  #29
hadfield4wd
Yeah my local Oreilly's had a vacuum advance diaphragm in stock. I am pretty sure I understand how they work.
I went back to the 2 stage pv. It's much better.
Old Oct 12, 2011 | 10:50 AM
  #30
Tknight85's Avatar
Tknight85
I'm interested in the bucket seats I'd love to take the brench out of my single cab and put some bucket seats and a console in it. Do you already have the seats if so where did you get them from?
