2000 trans shift problem...no second gear
Old Sep 11, 2011 | 01:47 AM
cody2000f250's Avatar
cody2000f250
Question 2000 trans shift problem...no second gear
Ive been without second gear for some time now. Shift 1-2 shows up on my code reader. I can goose it up to about 2500rpm and let off to get to the remaining gears. Does this sound like a shift solenoid problem? Has anyone changed them out? Are they hard to do?do they come in an assemby or individualy? Are they cheap???trying tosave a buck. I appreciate your time and input.
Old Sep 11, 2011 | 08:48 AM
izzybird's Avatar
izzybird
Hmmm, almost exact same symptoms as when the mechanical diode went out in the '01. Calls for a rebuild. The mechanical diode had a short run in some '01 trucks and yours shows to be a 2000. There's some good trans guys here, I don't have a good answer. Bump you to the top.
Old Sep 11, 2011 | 09:15 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
"Trying to save a buck".
You need a transmission rebuild as your intermediate sprag is toast.
Sorry.
Old Sep 11, 2011 | 09:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
By randomly replacing parts? This is usually the most expensive way to fix any problem.
That is most likely the problem.
Old Sep 14, 2011 | 07:13 PM
tkwolfe's Avatar
tkwolfe
I'm having the same EXACT problem that popped up 2 weeks ago. Will it get worse? If I keep driving it, will I make it even worse? I too, just don't have the bucks right now to spend thousands on a repair. Even if I took it to AAMCO, what is this going to cost me? Suggestions would be appreciated. Mine is a 2001 with 110,000 on it and was used pretty lightly over the past 10 years.
Old Sep 14, 2011 | 07:28 PM
Mark Kovalsky
I would suspect a low side would be about $2500, and high side could go over $4000. It is going to get worse until it won't go anymore. How long that will take is impossible to predict.
Old Sep 14, 2011 | 07:50 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It may last another 10K miles, or it may go 10 miles.
It depends on how much shrapnel you have floating around and what's being torn up by those metal pieces every mile you drive.
Old Sep 14, 2011 | 09:00 PM
tkwolfe's Avatar
tkwolfe
Thanks for all of your help, guys. I appreciate all the input. I'm waiting for some clarification from Mark on another thread, about the possibility of NOT having mechanical diodes in my SD.
Old Sep 14, 2011 | 09:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It doesn't matter. The intermediate sprag can fail in ANY of the E4OD or 4R100 transmissions. It's just that the design of the "mechanical diode" lends itself to breaking easier. It's still a one way clutch.
Old Sep 14, 2011 | 09:19 PM
Franko72's Avatar
Franko72
Molon Labe
Do yourself a favor and beg/borrow money to get a reputable trans rebuild, (BTS/JOHNWOOD)
I don't want to read another story like what happened to me.
I had three rebulit transmissions in my truck last year....because I "wanted to save money"
I finally wised up after waisting alot more money than If I would have had it done right the first time.
Read my sig...
Old Sep 14, 2011 | 10:45 PM
tkwolfe's Avatar
tkwolfe
Understood, Cody. Thanks. I do realize that anything can fail and will in time. And Frank, thank you, too. I'm not cheap, just broke. I may not even keep the truck, so I need to make some decisions on my next move.
VX-23 Hokie
Apr 10, 2012 11:20 AM
TWIGAL
Mar 2, 2009 04:32 PM
KiotiLee
May 25, 2008 07:48 AM
jdbanks
Nov 12, 2007 03:34 PM
lshort
Mar 17, 2002 05:09 PM
