Ranch to Save
Old Sep 10, 2011 | 02:20 PM
  #121
Aune163rd's Avatar
Aune163rd
Equipment Details
I found this in Great Falls, MT. I like the way this tractor looks, it has 10 more hp than the 2010 i was looking at and it comes with a loader, cab, grapple, snowblower, Cat II 3pt. I just want the tractor with loader....
Old Sep 10, 2011 | 02:31 PM
  #122
Aune163rd's Avatar
Aune163rd
So that tractor loader that you found on C-List for 1200, he offered to sell it to me for 1050....I offered 1000 and he took it.
Old Sep 10, 2011 | 02:32 PM
  #123
84-6.9L's Avatar
84-6.9L
Now that looks like something you will be happy with. But IIRC they have the shifter between your b%^&. They are good tractors, the blowers willbe nice in the nort as we call it over here. The grapple is good for grabbing logs, and this one will have a much heavier front end then the 2010 but not like the 2010 front end is too light.
The valve was listed separatly, did you get that too?
Old Sep 10, 2011 | 02:40 PM
  #124
Aune163rd's Avatar
Aune163rd
yeah i got the valve and the fittings for it. If i get that loader is it worth it? Think I should get a smaller bucket?
Old Sep 10, 2011 | 02:45 PM
  #125
84-6.9L's Avatar
84-6.9L
Any good loader is worth 1k around here. You could just cut the bucket down. Rent a gas powered cutoff saw with some blades, cut sections off the outside of the bucket and weld the ends back on. But put it on, try it out and see what you think. Its a good snow bucket but dont fill it with dirt. but you are probably going to move wood and brush and hay, for that its probably just fine.
Old Sep 10, 2011 | 02:49 PM
  #126
Aune163rd's Avatar
Aune163rd
I wanted to move dirt lol. Not much just enough to level a small part of the hill for the road thats goign in.
Old Sep 10, 2011 | 02:51 PM
  #127
84-6.9L's Avatar
84-6.9L
You can I just wouldnt recommend filling the bucket full.
Old Sep 10, 2011 | 03:01 PM
  #128
Aune163rd's Avatar
Aune163rd
I dont intend to...I just need to level it out, I plan to put the bucket down after I go over it with the blade to get rid of the sagebrush. then as I am going by on the second go around and put the bucket down and start digging....
Old Sep 10, 2011 | 03:07 PM
  #129
Aune163rd's Avatar
Aune163rd
Ok So I am going to go with taht 2010 and the loader, then remove the grapple and then shorten the bucket. Now I need to worry about finding cows, planting new grass & alfalfa mix hay and Establishing a base for the fence, I was thinking 4-6 strands of either barbed or barbless or a mix of both....what you think?
Old Sep 10, 2011 | 03:17 PM
  #130
84-6.9L's Avatar
84-6.9L
Id only shorten the bucket if you use it and think you need to. Personally id go with barbed wire, that way they wont be rubbing aginst the fence. When mixing grass with alfalfa dont mix in brome it grows too fast and heads out before the clover is ready. Orchard grass or timothy will mix well with alfalfa.
Old Sep 10, 2011 | 03:18 PM
  #131
Country_boy_2007's Avatar
Country_boy_2007
do six strands of barbed, or four strands of wire, and get a good fence charger. orchard grass and timothy grow very well together, and its very tough, stands up good to grazeing, and it'll grow anywhere. mix some clover in with it too
Old Sep 10, 2011 | 03:40 PM
  #132
Aune163rd's Avatar
Aune163rd
Thats what I had figured on doing. I knew I was going to run Timothy and Orchard, I heard good and bad about clover however.
Old Sep 10, 2011 | 03:56 PM
  #133
84-6.9L's Avatar
84-6.9L
alfalfa is a type of clover
Old Sep 10, 2011 | 04:51 PM
  #134
Aune163rd's Avatar
Aune163rd
yeah I know that. I was thinking a secondary clover.
Old Sep 10, 2011 | 04:58 PM
  #135
swooshcmk's Avatar
swooshcmk
high tensile fences they actually recommend that every other wire is electrified and the wires between are grounded. Better chance of the cow getting a good ground for the fencer to work. When we had the cows in pasture with 1 or 2 wire and no grounded wires they'd push their neck under the wires on dry days and not even bother them as they didn't have a good ground path.
