Ranch to Save
Old Sep 25, 2011 | 08:04 PM
  #166
Aune163rd's Avatar
Aune163rd
Your right about that. So anyway, The IDI is acting up, the real fuel tank is leaking now so i dropped it. Also, still having electrical issues. I replaced the rear harness(that little plug to the lights and whatnot) and it restored running lights, the blinkers work BUT the left blinker flashes both rears, and the right blinker flashes the reverse lights??? any idea what that could be?
Old Sep 25, 2011 | 08:06 PM
  #167
Aune163rd's Avatar
Aune163rd
I did however change the oil, oil filter, and air filter and now the IDI acts better FE wise(the old filter was at least 6 years old, i didnt know lol) and now I can roll coal if i want to, it wouldnt before....
Old Sep 25, 2011 | 08:14 PM
  #168
84-6.9L's Avatar
84-6.9L
sounds like bad grounds on your lights there
Old Sep 25, 2011 | 08:27 PM
  #169
Aune163rd's Avatar
Aune163rd
But the lights all work????
Old Sep 25, 2011 | 09:56 PM
  #170
84-6.9L's Avatar
84-6.9L
The ground may only flow so much electricity, or they could be grounding out. wherever the wires are touching steel make sure they are protected, and of course they could be touching each other due to poor insulation. but check your trailer plug wiring thats usually the culprit.
Old Sep 25, 2011 | 11:29 PM
  #171
Aune163rd's Avatar
Aune163rd
I bought one of those ones you plug into the rear harness....
Old Sep 26, 2011 | 08:51 AM
  #172
84-6.9L's Avatar
84-6.9L
Do you have a new plug on the end?
Old Sep 26, 2011 | 05:34 PM
  #173
bashby's Avatar
bashby
Bad grounds will cause the power to backfeed through other bulbs, making them light up also.
Old Sep 26, 2011 | 07:51 PM
  #174
Otahyoni's Avatar
Otahyoni
X2 on what bashby said.
It's weird how it happens, but thats what it does. Clean the ground wire where it hits the body and where its on the frame. See if it isn't working right after that...
Old Sep 26, 2011 | 08:45 PM
  #175
Aune163rd's Avatar
Aune163rd
Well i put a new ground in and it blows the tailight fuse...so idk what the heck is going on....but anyway....
Old Sep 26, 2011 | 10:16 PM
  #176
84-6.9L's Avatar
84-6.9L
Are you sure that one is the ground? If your running the 7pin rv plug there should be a gound on the plug itself, IIRC it's the white wire. Best get the test light out there and make sure everything is kosher.
Old Sep 26, 2011 | 10:39 PM
  #177
Aune163rd's Avatar
Aune163rd
oh no i only have a 4 way flat....
Old Sep 27, 2011 | 12:22 AM
  #178
cj06's Avatar
cj06
4 way flat will have 1 ground , the truck will need a ground as will the trailer !
Trailer Wiring Diagram For 4 Way, 5 Way, 6 Way and 7 Way circuits
Old Sep 27, 2011 | 12:35 AM
  #179
swooshcmk's Avatar
swooshcmk
Yup, white ground, brown tail lights, yellow = left stop/turn filament, green = right stop/turn filament.
Ford uses brown for the tail lights, so that's a direct color match. I'd have to look up the stop/turn colors on the truck side if you need 'em.
*edit* Just realized CJ06 just before me posted a link to the trailer diagrams.
Old Sep 27, 2011 | 12:38 AM
  #180
Aune163rd's Avatar
Aune163rd
Well I am not worried about pulling trailer, when I pull trailer it does the same thing, I am thinking about pulling my 86 harness from the connection at the rear of the truck forward, then going from there and seeing what happens.
