6.9l customization
Old Jul 16, 2012 | 05:46 PM
  #181
turtlemann14's Avatar
turtlemann14
eh nmb2 has a set similar, but still different.
now i just need to find out how to make the turn at the end of the head without it being sharp.
has anyone made their own air filter box?
how would i look up air filter sizes and such?
Old Jul 18, 2012 | 12:14 AM
  #182
88 Ford IDI's Avatar
88 Ford IDI
Those look nice man. A lot of guys use the BHAF. NMB2 is using one that flows like 900cfm iirc. I don't remember what kind of filter out is though but out flows really well though.
Old Jul 18, 2012 | 01:14 AM
  #183
NMB2's Avatar
NMB2
my only concern with those is how thin they are. Other than that they look bitchin'
Old Jul 18, 2012 | 04:25 PM
  #184
turtlemann14
i know, but i think the stainless will cover that (i hope)
i should have gone with 12ga
Old Sep 15, 2012 | 08:17 PM
  #185
turtlemann14
almost done with the manifolds, and i keep looking at how the hot side of the turbo.
kinda thinking about posting it on ebay and moving up to a gtx3582r
Old Sep 16, 2012 | 01:01 AM
  #186
88 Ford IDI
Any pics of the manifold? Also with that turbo size, if you go with the other turbo, you could look at a Ford 6.0 vgt. Iirc it is a gt3782v. That would spool really well on your engine and you could control it pneumatically. There is a guy over on OBN running a he351ve remotely under his bed and it still spools well. A vgt would spool even better in the engine bay.
Old Sep 16, 2012 | 08:28 AM
  #187
turtlemann14
i would keep the gtx wheel for sure, i wonder where i could pic up a vgt housing that would fit a gt30r or gt35r frame?
the gtx wheel is what makes these turbos, it's about on the same level as the wheel in nmb2's turbo so i can have smaller wheels and keep flow.
yea, i will get some pics soon, my welds are junk on them but that is what a grinder is for right?
on a side note, i was blowing air down through the ports and the ones that i wasn't blowing air in were pulling air in, so i guess that is a good thing.
Old Sep 16, 2012 | 11:46 AM
  #188
88 Ford IDI
I know a lot of the TDI guys swap wheels on the smaller vgts, so you might be able to do it. You might be able to do it with a 6.0 turbo and make out work. Also you might have to have it balanced if you do it.
Also I look forward to the pics.
Old Sep 16, 2012 | 05:17 PM
  #189
turtlemann14
how did they cast this? it's so smooth.
had to wrap this one around the oil cooler a bit so that it would clear the cab.
and i am not sure how to do the last bit yet.
what do i need to look for regarding inter coolers to make them efficient? i was looking at this one http://www.cxracing.com/mm5/merchant...ry_Code=IC35CO
keep in mind i have the short wide rad.
Old Sep 17, 2012 | 03:01 PM
  #190
brads93 idi's Avatar
brads93 idi
Them exhaust manifolds look good
Old Sep 17, 2012 | 08:59 PM
  #191
88 Ford IDI
Its definitely looking good. As far as your intercooler question goes, are you asking how to size it?
Old Sep 17, 2012 | 10:15 PM
  #192
91dirtydiesel's Avatar
91dirtydiesel
I like my big 99-03psd IC, sure it dropped the boost a bit but also dropped EGTs on average of 150-200egts
Old Sep 18, 2012 | 05:41 PM
  #193
turtlemann14
basically how to size it for maximum efficiency.
least boost drop, low lag, and best thermal transfer.
i figure that you can do better than stock, kinda why i am looking at aftermarket.
the only thing i really don't like about the one that i posted is that there are no baffles/flutes to help disperse the air though all of the tubes.
and thanks, i just hope they hold up well.
Old Sep 18, 2012 | 11:29 PM
  #194
88 Ford IDI
I think some companies have flow and efficiency graphs. Other than that, its just the size and outlet size from what I know.
Old Sep 19, 2012 | 06:41 PM
  #195
turtlemann14
i figure there is a way to figure something out. i guess you could just add up the surface area of the pipe and make sure that the ic has as much or more than the pipe
