6.9l customization
Old Mar 12, 2012 | 09:47 PM
  #106
88 Ford IDI's Avatar
88 Ford IDI
Where is your turbo gonna sit?
Old Mar 13, 2012 | 05:19 PM
  #107
turtlemann14's Avatar
turtlemann14
in the rear like the power strokes or the banks kit.
the more i think about it i think i am going to go with a slightly longer runner and a manifold high enough that you can get the glow plug in and out decently easy
Old Mar 13, 2012 | 06:51 PM
  #108
88 Ford IDI
That sounds good. Are they gonna be tubular also for better flow?
Old Mar 13, 2012 | 06:53 PM
  #109
88 Ford IDI
Also when are you gonna start all this?
Old Mar 14, 2012 | 06:02 PM
  #110
turtlemann14
what do you mean by tubular? as in round instead of oval?
well, i am in the process of ordering my turbo at the minute. i am having the welder at work stick some pieces of stainless together for crucibles. (i need a gas welder, this flux core sucks lol)
and the weather is good right now, so basically as soon as i get some sand made and don't have to work on the weekend lol
and i still have to make the positive molds
Old Mar 14, 2012 | 09:01 PM
  #111
88 Ford IDI
Ya I meant round ports and stuff. Kinda like the Banks ones on the Duramax. Also what kind of turbo are you getting?
Old Mar 15, 2012 | 05:14 PM
  #112
turtlemann14
like the banks big hoss? if so then yes
gtx3076r 1.06ar twin scroll exhaust, ported comp housing
Old Mar 15, 2012 | 06:20 PM
  #113
88 Ford IDI
What is the size of the compressor housing inducer and exducer? Also you don't think the 1.06ar will spool a bit slow even with the twin scroll?
Old Mar 15, 2012 | 07:27 PM
  #114
turtlemann14
comp: 58mm inducer, 76mm exducer, trim 58 ar 0.6
turbine: 60mm(not sure if this is the turbine inducer or exducer) , trim 84
30 frame size
gtx wheel
dual ball bearing
nope, i have a plan for that
in the end it will be about a .53 ar at idle and 1.06ar cruising or when boost is above say 5 psi
Old Mar 15, 2012 | 08:30 PM
  #115
88 Ford IDI
OoooH. You gonna get one of those boost referenced flap that keeps exhaust in one scroll and then at a certain boost level opens up fully? That will be cool for sure. I've wondered if anyone would ever do one on an idi.
Old Mar 16, 2012 | 06:33 PM
  #116
turtlemann14
lol yea i am going to try. i hope it works well, i am just worried about getting a high enough grade of stainless because i really don't want it melting and going into the turbine.
Old Mar 16, 2012 | 06:40 PM
  #117
NMB2's Avatar
NMB2
thats a pretty small turbo.
Old Mar 16, 2012 | 10:39 PM
  #118
turtlemann14
how do you figure?
are you accounting for the gtx wheel?
Old Mar 16, 2012 | 11:56 PM
  #119
88 Ford IDI
What Justin means is the compressor is a bit on the small side depending on how much boost you want. What is your target boost anyway turtlemann?
Old Mar 17, 2012 | 07:59 AM
  #120
turtlemann14
20lbs, but according to garrets web sight that compressor should be good up to 30 psi and still be over 50% efficient
you would have to have something like a 88mm with a gt series wheel
