Tightening Ignition Switch
Old Sep 18, 2011 | 11:06 PM
  #31
pgr380's Avatar
pgr380
Ig Switch Follow Up
Finally got around to pulling the ig switch. Couldn't have done it w/o the excellent instructions you guys posted.
Anyway, I found all pieces to be in order, except that one of the posts on the switch itself was broken. Bought a new switch and installed it; works fine, except that the whole assembly (bezel and lock cylinder) still rotates, although not as easily as before. I was careful to make sure that the 3 tabs on the bell shaped thingy engaged the slots in the dash. Any idea what else I can do to keep it from rotating?
BTW, the switch I got from NAPA had 4 terminals instead of the 3 on the original switch. What is the additional for?
Old Sep 19, 2011 | 03:22 PM
  #32
B-2's Avatar
B-2
bezel
I am still looking for a ign. bezel I really just need the bezel I will buy a new switch unless it has a good working one with the bezel. So if anyone has one laying around that they want to sell let me know. I am still checking the truck over after buying it, the drive train is all new but they just never used lock tight on any thing they put in. So I am taking everything apart to put lock tight on the bolts. It has a rebuilt 460 with Alum. heads I just never got the info that he told me he had. The motor runs great it was done by a shop, so I lucked out there. Just need a bezel so I can take out the AutoZone switch, & put in the right one.
Thanks Bill
Old Sep 19, 2011 | 05:22 PM
  #33
Bill W's Avatar
Bill W
Thanks Bill
http://www.parts123.com/parts123/yb....Z5Z5Z50000024G
Old Sep 19, 2011 | 05:44 PM
  #34
B-2's Avatar
B-2
Thanks Bill I guess I am getting old I checked their site & could not find it any were.
Thanks Bill
Old Sep 22, 2011 | 12:37 PM
  #35
Confederate Diesel's Avatar
Confederate Diesel
Ground at START for a brake warning light witness circuit.
Makes a nice upgrade with a '67-'72 brake warning light in the dash if you have upgraded to disc brakes.
Old Sep 22, 2011 | 02:32 PM
  #36
OldHarley's Avatar
OldHarley
Makes a nice upgrade with a '67-'72 brake warning light in the dash if you have upgraded to disc brakes or dual circuit drums.
Thanks, I am going to upgrade to these in the future.
Old Feb 3, 2026 | 11:00 PM
  #37
Planeview's Avatar
Planeview
2nd Gear
Awesome info!
Originally Posted by 65jim
Here you go, pgr 380. Maybe this will help end the confusion the Self-proclaimed know-it-all started. The two horizontal notches are the locking notches to keep it from turning. The other three are to hold the cup behind the hole in place to keep the switch straight in the dash hole.Here are the tabs on the bezel I was talking about.
I just went through two spacers thinking I got the wrong size so it wasn’t putting enough tension on the spring to keep it from rotating the whole assembly! The notches in my dash are completely worn out, I didn’t even know it was supposed to have them haha. I’m a recent owner of a 66 F100 so I have a lot to learn. Any advice on a remedy for my situation?
Old Feb 4, 2026 | 11:00 AM
  #38
gstrom99's Avatar
gstrom99
Welcome!
Got a pic of the boogered up hole? I don't know if a ready-made patch piece is available (doubtful). You may be able to weld it a bit and then dremmel/file it to remake the notches.
Old Feb 4, 2026 | 01:12 PM
  #39
rusty valley's Avatar
rusty valley
put a chunk of brass in behind the hole to keep the inside surface flat, then weld up the bad notch and file in a new one
Weste
Oct 18, 2014 08:40 PM
rob8210
Apr 1, 2013 05:40 PM
BPB
Jun 7, 2012 12:07 PM
cbeer68
Nov 14, 2010 07:48 AM
mikes66
Mar 4, 2001 01:25 PM
