68 ignition switch
Old Nov 13, 2010 | 02:42 PM
cbeer68's Avatar
cbeer68
68 ignition switch
How do I remove the ignition switch out of the dash of a 68 bronco? It does not appear to use a three prong tool like a late 70 model does.
Old Nov 13, 2010 | 05:12 PM
jowilker's Avatar
jowilker
cbeer, If it has a paper clip size hole at about 4 o clock, insert the key, turn it to the acc position, insert a paper clip into the hole and turn the key flat then pull the cylinder out. Reach behind the dash, grab the switch while pressing against the bezel push it in and twist it 1/8 turn counterclockwise.
You should have it separated.
John
Old Nov 14, 2010 | 07:48 AM
cbeer68's Avatar
cbeer68
Ok, thanks
