IPR normally goes from 200-250. i would just use a small pipe wrench thats what i used. if you do studs more than likely you wouldnt have to worry about the motor but you would need to update some things while your there. dont do the "one at a time" method its to risky! if you do studs replace the gaskets, standpipes, plugs, stc fitting, ect... i can give you a list if you want me to
here is what i would get.
gaskets
studs
stc fitting
dummy plugs
standpipes
blue spring kit
injector o ring kit
intake gasket kit
bullet proof egr cooler
oil cooler
but since you have some of that you can take it off thats just my list though and someone chime in if im missing something i believe i am but then again my mind doesnt work that well late at night
I am searching every angle and just can't find a way to get to it without removing the turbo. From top I can't get to the plug to disconect and from the bottom I can't reach it. Any ideas before I start removing turbo?
Well................... I just tried gently to remove the screen and the plastic that holds the screen shattered. So I need one regardless now. Is there anything I should do while I wait on the new one to come in. Clean HPOP, or maybr the turbo?
