Australia Chapter Join Chapter , Leader: OPEN
Motor Build
Old Sep 13, 2012 | 04:57 AM
  #121
SSSimon's Avatar
SSSimon
As the engine hasn't been warmed maybe the RTV won't have set. It might still be tacky.
Old Sep 16, 2012 | 03:50 AM
  #122
ChunderDownUnder's Avatar
ChunderDownUnder
well I found me low pressure problem. The cause was the idiot who put the engine together. Yep me
those two wholes near the cam need freeze plugs dont they
Old Sep 16, 2012 | 05:36 AM
  #123
redroad's Avatar
redroad
with the motor out you can maybe pull the dizzy and with a drill motor and a home made extended oil pump shaft in the drill motor, spin the drill motor and the oil pump to try to isolate the problem.. Just a thought
Old Sep 16, 2012 | 06:10 AM
  #124
ChunderDownUnder
your kidding, right ????
Old Sep 16, 2012 | 07:17 AM
  #125
redroad's Avatar
redroad
Nope .. that is how we pre lube fresh rebuilt before initial start up to make sure all it's bits are getting oil .. the worst internal wear on engine can happen on initial fire if not pre lubed
Old Sep 17, 2012 | 04:26 AM
  #126
SSSimon's Avatar
SSSimon
C'mon, this could work if:
1) you had a bloody GIANT drill;
2) your diesel engine had a distributer drive on its cam shaft ! ?? !
Old Sep 17, 2012 | 07:05 AM
  #127
ChunderDownUnder
Simon picked it on point 2. Its a diesel bruva - No dizzy and no plugs either. But thanks for da tip.
Every thing internal had a healthy coat of Clevite assembly lube. Running it for the 60 seconds when it finally started wouldnt have done any damage. There is fresh oil in all the right places , just not enough with those galley plugs missing. Im just happy I found the problem and put the engine back in.
Old Sep 17, 2012 | 08:22 AM
  #128
redroad's Avatar
redroad
Missed the diesel motor part
For gas engines the drill motor method works great to get the oil galley plugs sorted before install..
It sounds like your on way now mate .. Good luck .. Nice thread by the way
Old Sep 18, 2012 | 06:14 AM
  #129
SSSimon's Avatar
SSSimon
Yep Red, the F250 7.3 is a thumping great cast iron diesel motor designed by International Harvester, the stock motor redlines at 3,750 RPM, the pistons are so big there's an oil jet under each one squirting cooling oil up to cool the piston centre. Forget EFI, the fuel injectors are opened via a timed high pressure (3000psi) pulse of engine oil through special high pressure galleries to the fuel injector nozzles.
Brian, what about the hole lower down on the RHS of the photo - looks to be similar to the plug holes near the cam?
Old Sep 18, 2012 | 08:52 AM
  #130
BadDogKuzz's Avatar
BadDogKuzz
Brian I am glad you found the problem !!
Old Sep 30, 2012 | 01:34 AM
  #131
aussie_f350's Avatar
aussie_f350
Any updates?
Old Sep 30, 2012 | 09:16 AM
  #132
ChunderDownUnder
waiting for Clay to send over the freeze plugs and a new rear main seal. 3 weeks now and Im getting pi$$ed.
Old Sep 30, 2012 | 03:21 PM
  #133
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I am sorry, but special orders take time to get in. We had to order a package of 24 of these just to get your 3 as that is minimum package quantity.
Old Sep 30, 2012 | 05:21 PM
  #134
ChunderDownUnder
just venting my frustrations bro. You know I luv ya. Its just my neighbors arent your biggest fan. I have to use my concrete truck to get to and from work now. It takes a few minutes each morning (4-5am) to build up air and they tell me its quiet loud.lol.
Oh and its 4 bro. Put em on PA. should be able to get rid of a few
Old Oct 1, 2012 | 07:21 AM
  #135
aussie_f350
Be worth the wait I'm sure!!!
