Australia Chapter Join Chapter , Leader: OPEN
Motor Build
Old Jan 16, 2013 | 12:32 AM
  #181
ChunderDownUnder's Avatar
ChunderDownUnder
Originally Posted by SSSimon
Hi Brian, the engine and turbo sounds great - from the vid I can see:
1) some puffs of black;
2) you're running a snorkel;
3) headlights on...
Did you also record the runs on your AE? Given that there's black coming out my layman's thinking is that your fuel (HPOP and injectors) are pushing enough fuel in. Could it be the restriction in air intake?
How accurate is the dyno? Is it worth trying another dyno for a second opinnion?
For an extra 0.2 of a HP turn the headlights off
Lastly - was the dyno calibrated in KW and the graph using HP? - cause 398.8KW = 534HP - a 'funny' coincidence as that is about what you were expecting.
Certainly Bryan's seat of the pants review called it 500hp+ 3rd gear wheel spinning sideways etc...
The dyno was at PKW auto who is a well respected Drag racer and engine builder. I can only rely on he's expertise.
The "All Out" tune is gunna blow smoke, whether it be 400 ponies or 500. Thats what its spose to do. You really have to fuel em up to get those #'s
My laptop has **** itself so I couldnt get any AE data which at this stage is what I really need.
The main idea of the run was to get the HP cause I new from the get go I wasnt at the 500 mark.
Now that it is confirmed I can do the necessary test (once I get my laptop going) to eliminate either a lack of boost, drop in fuel pressure or a weak HPOP.
The way the curve flattens out sort of leads to either 3 or a combination.
Just put it out there cause peeps were asking for updates and I wanted to get the Youtube ****e sorted.
Im thinking of putting her on the rollers again once I have AE. It was only $150 for the run.
Oh, the headlights were on so he could see the instrument panel in the cab. It was quiet dark in that corner. And yes bro, it is in HP not KW.
If all checks OK my end then its back to Matt re the toons.
Old Jan 16, 2013 | 01:16 AM
  #182
Nkelly's Avatar
Nkelly
Farkall User
Originally Posted by ChunderDownUnder
that was some shmuck drivin me truck. blew the IC boot off and just laughed.
Hey you laughed first, me me was more unhappy about it than the pair of us..
Old Jan 16, 2013 | 03:09 AM
  #183
SSSimon's Avatar
SSSimon
Bryan: Very impressive loading job at #177 !
Brian: Looking forward to hearing what the issue is with the engine. When it's done you'll have to get your 'test pilot' there to give it another once over
Old Jan 16, 2013 | 04:55 AM
  #184
Nkelly's Avatar
Nkelly
Farkall User
Biggle's cap and glasses under the arm,ready when you are..
Old Jan 16, 2013 | 04:59 AM
  #185
Nkelly's Avatar
Nkelly
Farkall User
Now that it is confirmed I can do the necessary test (once I get my laptop going) .
Hey,now i never took that for a spin,dont blame me..
Old Jan 16, 2013 | 05:19 AM
  #186
SSSimon's Avatar
SSSimon
With another 100+ ponies coming out from under the bonnet Brain had better get a set of drifting tyres before he lets Biggles loose next time!
It'll be sideways on the dry bitchy in 4th - it'll be like Clarkson in that V8 Mercedes on that test track in Spain - the new rear tyres lasted 28ks.
Old Jan 16, 2013 | 02:00 PM
  #187
wallsy's Avatar
wallsy
Is Bryan the real STIG??????
Old Jan 16, 2013 | 02:50 PM
  #188
Nkelly's Avatar
Nkelly
Farkall User
As you can see in my sig, ive got the helmet on
Old Jan 17, 2013 | 01:32 AM
  #189
wallsy's Avatar
wallsy
You will probably need that helmet, the way Brians truck go,s mate, when you aren't busting it!
Old Jan 17, 2013 | 02:28 AM
  #190
ChunderDownUnder
Just one thing. A bloke was at work was telling me that US horsepower is different to Aussie horsepower. You can take about 13% of the US mark to get the Aussie equivalent. Any one heard of that. Maybe Adrian can chime in.
Old Jan 17, 2013 | 04:09 AM
  #191
aussie_f350's Avatar
aussie_f350
Heard of USA engines dynoed over there not making anywhere near the same hp here. Atmospheric pressure is different or something. Not sure, I was reading about shafiroff big block chev engines when I read it
Old Jan 17, 2013 | 05:25 AM
  #192
Diesel Submariner's Avatar
Diesel Submariner
US HP & METRIC HP
G'day Brian,
I reckon we use the Metric Horsepower as the Standard International Unit.
That is 1 x Metric Horsepower = 735.6 Watts or 0.986 Standard Horsepower (US Horespower).
That is 1 x Metric Horsepower is 98.6% of 1 x US Horsepower.
Maybe this is the issue??
Cheers,
Reg
Old Jan 17, 2013 | 05:31 AM
  #193
Nkelly's Avatar
Nkelly
Farkall User
I know in the big trucks european HP is less than US HP..
So yes bwian oils aint oils,HP aint HP
Whats Horsepower (mech) and Horsepower (metr) ?
Old Jan 17, 2013 | 05:39 AM
  #194
Nkelly's Avatar
Nkelly
Farkall User
I didnt bust it,he yes him got over excited with da chroming,woops i mean the chrome on his IC pipes
geez
Old Jan 18, 2013 | 01:22 AM
  #195
ChunderDownUnder
Hi Reg
I have read about the metric (HP) but I do believe the US also use the metric (HP) as well. As you quoted the difference is minimal. The guy at work was talking around 13%.
I know with the big European trucks (MERC. Scania, Volvo) HP is different to ours. Like a 540HP volvo will be 500HP here.
