backfires
Old Jun 27, 2011 | 02:19 PM
Skinner F350's Avatar
Skinner F350
Yes she did just pull in to fuel up, and I did ask her this, It was diesel. Plus she drove about 130 km's after fuelling up. The dipstick look like a normal level but I will drop the oil any way. It was almost due anyway. Now I have to search this site for glow plug and injector removal. Also been trying to find the buzz test in here. no luck yet.
Old Jun 27, 2011 | 02:23 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Check the 6.0 tech folder sticky at the top of the page
Old Jun 27, 2011 | 03:18 PM
High Binder's Avatar
High Binder
Originally Posted by High Binder
Did she hit a gas station just before this happened, maybe filled up with gasoline instead of diesel?
Well, it is entirely possible that she pumped in water laced diesel fuel and the back-firing was the early sign of hydro-locking.
I think it's worth looking at your fuel and perhaps swapping out/making sure your water separator system is actually working. There are a lot of fuel filters for our trucks that don't have the separation feature... If you pull some fuel from the fuel pump into a plastic container give it a few mins to settle and see if you see water in the fuel. It'll look like cloudy bubbles in clear green fuel.
Old Jun 27, 2011 | 08:01 PM
Skinner F350
well pulled all glow plugs, now have to charge up batteries to crank over. 4 way flashers on to long yesterday. I have been looking through the tech file but cannot find the buzz test. I tried to get at glow plugs without pulling inner wheel on right side with no luck. Sucks to pull mud flap, chrome fender flare also but alot easier to get at. which post has buzz test..
Old Jun 27, 2011 | 11:02 PM
cartmanea's Avatar
cartmanea
The buzz test is done with AutoEnginuity or Ford's tool.
Old Jun 27, 2011 | 11:40 PM
BLADE35's Avatar
BLADE35
Iv heard cheezit mention a mist test while glow plugs are out
not shure about how to do it
but I think you pull the ficm fuse so injectors dont fire and watch for mist out the GP hole from an Injector thats stuck on as someone cranks it over
It was brought up in a blown egr cooler thread about the mist test but I would assume you could do the same for a bad injector thats stuck on
any of you guys ever do a mist test
Old Jun 28, 2011 | 06:11 PM
Skinner F350
Ok I just put charged batteries in with glow plugs out and cranked the engine over, alot of fuel comes out of the drivers side glow holes but hardly any thing from the other side. The drivers side fuel sprays out to the fender but the other side has a little trickle come out. any info.
Old Jun 28, 2011 | 06:53 PM
BLADE35's Avatar
BLADE35
did you pull the ficm fuse
If the ficm off only bad injectors should spray fuel out cause there stuck open right
I also thought you would only see mist out number 4 cylinder GP hole
and cylindert 4 is second cylider back driver side
Old Jun 28, 2011 | 07:08 PM
Skinner F350
Did not pull FICM fuse. I will try that. When I find that fuse. Thanks
Old Jun 28, 2011 | 07:25 PM
Skinner F350
Just wondering, should there be fuel coming out of all glow plug holes when cranking.
Old Jun 28, 2011 | 07:49 PM
BLADE35's Avatar
BLADE35
with the ficm fuse still in yes its doing its normal thing firing the injectors trying to start
when you pull that fuse or ficm relay only injectors that are stuck open should spray or mist out the GP hole
Old Jun 28, 2011 | 08:20 PM
Skinner F350
ok , which fuse # is the ficm.
Old Jun 28, 2011 | 08:38 PM
  #28
BLADE35's Avatar
BLADE35
read thru this it has good pics of ficm and componets
<TABLE style="WIDTH: 254pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=339><COLGROUP><COL style="WIDTH: 254pt; mso-width-source: userset; mso-width-alt: 12397" width=339><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 254pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 height=17 width=339>• 6.0L FICM Guide - 6.0L</TD></TR></TBODY></TABLE>
click here^^^^^^^^^^^
lots of good info in Bismics spread sheets do you have the spreed sheets
Old Jun 28, 2011 | 09:11 PM
  #29
Skinner F350
I replaced the FICM about a month ago. Just wondering. If I might have a bad unit, Have to test this one I guess. It just seems that the fuel was coming out the exhaust when she was driving the truck. I should put the glow plugs back in and try an start it to see what happens.
Old Jun 28, 2011 | 09:20 PM
  #30
BLADE35's Avatar
BLADE35
if the ficm lost a injector driver it usualy wont fire the injector I suppose it could fail in open position
If its only a month old it could fail but I doubt it you wont be able to test for an bad injector driver only can test ficm volts
https://www.ford-trucks.com/forums/8...procedure.html
I think cylinder 4 injector failed and is dumping fuel threw your system out the tail pipe it sounds like its stuck on FWIW
to me a failed injector just fits the codes you have
