Offroad & 4x4
The 94 says enough is enough.......
Old Jun 23, 2011 | 12:47 PM
  #46
hav24wheel's Avatar
hav24wheel
So basically making it a mechanical secondary carb?
Old Jun 23, 2011 | 12:50 PM
  #47
tjc transport's Avatar
tjc transport
i ain't rite
yup.
quick and easy
Old Jun 23, 2011 | 12:56 PM
  #48
tjc transport
i ain't rite
and setting vacuum regulator valves on diesels for the C6 trans.
  #49
hav24wheel's Avatar
hav24wheel
Would u really need the copper tube?
Only vac, secondary carb I have screwed with is a old thermo quad or whatever my old Imperial had. I just used a piece of wire on it, had to slowly get on it from a stop, but a 30 drop it would go like mad
Old Jun 23, 2011 | 01:00 PM
  #50
alpha/omega's Avatar
alpha/omega
The screw in the linkage will kinda make it a half **** wanna be mechanical. In your application I wouldnt do it. Among other issues you'll most probably have a flat spot when the secondaries are supposed to kick in because you dont have 2 squirts of fuel.
Its just an old trick on a Holley.
Buy the spring kit and do it right.
Old Jun 23, 2011 | 01:03 PM
  #51
hav24wheel's Avatar
hav24wheel
Lol, well the carb is basically a holley, and has a provision for a second accelerator pump, but with all that its easier to "do it right" n use the springs.
Old Jun 23, 2011 | 01:05 PM
  #52
fatdan460's Avatar
fatdan460
manual secondaries ftw!!!! i'll tell that motor when to eat
Old Jun 23, 2011 | 01:31 PM
  #53
hav24wheel's Avatar
hav24wheel
If I get this tuned right it should work great for me, I the sound if it sucking air drowns out my exhaust from inside the cab!
Old Jun 27, 2011 | 03:33 AM
  #54
hav24wheel's Avatar
hav24wheel
After some miles on it pulling the camper, one short 50 mile trip I got 10 mpg, than I got about 7 mpg on a 140 mile trip on a hilly curvy road. I ran 4th gear most of the way, and tried to run between 60-65 the whole time. But as luck would have it, the wind was fighting me the whole time. I did drop to 3rd on ONE hill, ran 4000+rpms up it.
But I can't help but wonder, how much of a difference would changing out my current cam www.summitracing.com/parts/CCA-35-255-5/ for something bigger, or swapping better heads on would make make. I guess I haven't really ran it up to the 5200 rpm max of the cam yet, so a bigger cam is a mook point.
Old Jun 27, 2011 | 03:48 AM
  #55
82F100SWB's Avatar
82F100SWB
Since you don't need to compromise your cam to keep the computer happy any longer, I'd go with something like this COMP Cams 35-239-3 - COMP Cams Xtreme 4x4 Camshafts - Overview - SummitRacing.com
Should be a big improvement in power. A good set of heads wouldn't hurt either... LOL
Old Jun 27, 2011 | 11:13 AM
  #56
hav24wheel's Avatar
hav24wheel
Or I could swap some 1.7 rockers on, cheaper/easier than a cam swap, and gets me 508/515 lift...
Old Jun 27, 2011 | 11:40 AM
  #57
alpha/omega
But no duration or lobe separation
Old Jun 27, 2011 | 11:52 AM
  #58
hav24wheel's Avatar
hav24wheel
Ya........ That's kinda why I'm still debating what to do. But I guess always start with rockers, and if I don't like it, swap cams and it will make it that much beTter.
Old Jul 5, 2011 | 03:58 PM
  #59
jokerforever's Avatar
jokerforever
Hey bud, were are you at in ND? I may want to take your old EFI stuff off your hands if you still have it.
Old Jul 5, 2011 | 04:03 PM
  #60
hav24wheel's Avatar
hav24wheel
Bismarck is the are.
