Well it runs, I haven't drove it, as I'm having fuel return issues. The return line can hold 20 psi. So, I'm going to have to replace it, or find the restriction.
oooh forgot about the high pressure fuel pumps.
if you have a dual pump system, you will need to eliminate the in frame high pressure pump. you want no more than 7 lbs to the carb.
For your build all you need is a good deadhead regulator and forget about the return. Id just cap it off at the tank or loop the return from one tank to the return of the other.
Automotive A1000 pump and a A1000 regulator. Ive got 700lbs/hr of fuel going through a -10 (5/8") feed line at 45psi and the regulator steps that down to 5.5-6psi at the carb.
