Sponsored by: Real Truck
Steering Stabilizer ?
Old Jun 13, 2011 | 11:05 AM
cliwel's Avatar
cliwel
Have a 05' F250 SC FX. Would like to tighten up the steering. I can't see where it has a "steering stabilizer." How do I ad a dual steering stabilzer? Do I need to mount a bracket? Any help is appreciated. New to the truck world.
Old Jun 13, 2011 | 11:10 AM
jc8825's Avatar
jc8825
The steering stabilizer looks like a shock mounted horizontally under the front bumper. You should be able to see it just by glancing under the truck. Yours might be worn out if you are having issues.
You could add a dual setup like the one Rancho sells, but unless your truck is lifted with large tires, it is unnecessary, as the single setup is perfectly sufficient.
Old Jun 13, 2011 | 11:13 AM
cliwel's Avatar
cliwel
I am putting the Bilstein 2.5" Leveling Kit on next week. Is this enough of a lift to justify the dual stabilizers?
Old Jun 13, 2011 | 11:15 AM
jc8825's Avatar
jc8825
What size tires will you be running?
Old Jun 13, 2011 | 11:22 AM
cliwel's Avatar
cliwel
probably 33" or 34" tires, but maybe 35"
Old Jun 13, 2011 | 11:27 AM
jc8825's Avatar
jc8825
35s would be to the point where I would start considering maybe a dual setup. 33s, I would just stay with the single. You can tighten your steering box (I have not done this, so I couldn't tell you from experience), but supposedly there is an adjustment screw on it to tighten steering, but too tight will cause a binding issue.
Old Jun 13, 2011 | 12:07 PM
cliwel's Avatar
cliwel
But you are sure my truck has a steering stabilizer?
Old Jun 13, 2011 | 12:36 PM
jc8825's Avatar
jc8825
If your truck is an 05, it should. If there are any SDs that didn't it would be the early ones. I have never seen a SD without one. Just glance under the front of your truck really quickly.
Old Jun 13, 2011 | 02:53 PM
cliwel's Avatar
cliwel
Found it! Thanks!
Old Jun 13, 2011 | 06:35 PM
pbeering's Avatar
pbeering
I installed the Icon dual stabilizer on the '08 and love it. Second only to the Bilstein shocks, it is the best mod on the truck.
Old Jun 13, 2011 | 09:31 PM
billybop90's Avatar
billybop90
I installed a Bilstein single setup on the front. Definitely worth the money and you can actually tell the difference.
Old Jun 13, 2011 | 10:21 PM
rudedogii's Avatar
rudedogii
Ranch Dual Kit
I got a new Rancho Dual stabilizer kit #RS98510. I think its for your year model. I'd have to look it up.
I'll sell it to you for a hundred bucks if your interested. Send me a PM if you want it.
nghtrgr
Jun 2, 2010 12:34 AM
mdwilli
Apr 21, 2009 10:25 PM
hammer65
Feb 27, 2009 05:18 PM
THEDON117
Oct 31, 2008 10:19 PM
epos48
Feb 27, 2006 07:21 PM
