steering stabilizer
Old Feb 27, 2009 | 06:32 AM
hammer65's Avatar
hammer65
steering stabilizer
How do I test the steering stabilizer, on my 2003 diesel.
I am still trying to tweak the steering. It still a little bit of a wanderer.
Thanks again foe all your replies. Jim
Old Feb 27, 2009 | 06:39 AM
shawn_N's Avatar
shawn_N
maybe i will stand corrected, but the steering stabilizers sole purpose is to take the bumpiness out of the front end. though it may help some in the wondering, but i woudl start by checking tire pressure, and then checking the alignment. The only reason i say this is because i am going through the same thing.
Old Feb 27, 2009 | 06:49 AM
SGnAZ's Avatar
SGnAZ
For about 35 bucks, you could just replace it.
Old Feb 27, 2009 | 06:52 AM
hammer65's Avatar
hammer65
Thanks Shawn: Fresh alignment, Ball joints checked, Tire pressure at 60 psi. Good tires.
I just want to check everything, before trying adjustable Ball joints and tinkering with the caster/camber settings. Thanks Jim
Old Feb 27, 2009 | 09:05 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
The steering stablizer isn't causing your wandering problem. I just went through this myself. I would look at the ball joints first. Then check the tie rod ends. Is the truck lifted? Check the pitman arm to steering box connection. Another thing to check, and this is what caused my problem, is make sure that the rear end is aligned square to the frame. Mine was out and the truck was scary to drive. Had it aligned two weeks ago and she drives straight now.
Old Feb 27, 2009 | 09:09 AM
Ponyboychris's Avatar
Ponyboychris
Funny you mentioned that Scott, I followed a Superduty home from work yesterday and it was crab-walking down the highway. I couldn't tell if the front end was whacked or the rear was out of alignment. It was apparent from driving behind though.
Old Feb 27, 2009 | 09:14 AM
redfire42's Avatar
redfire42
What would cause the rear end to be misalined?
Old Feb 27, 2009 | 09:15 AM
Gcrop's Avatar
Gcrop
After reading your post about that a week or two ago, I had mine checked and it came back ok. I think my issue is more of a loose steering gear though.
Old Feb 27, 2009 | 12:19 PM
RussB's Avatar
RussB
My rear end was out of alignment because I had 2 broken rear leaf springs ! Pics in my gallery !
Mt truck is a nasty wanderer as well.. Haven't been able to fix it yet !
Old Feb 27, 2009 | 05:18 PM
shawn_N's Avatar
shawn_N
so when checking the pitman arms, what are you looking for?
bizzelj
Jul 12, 2015 10:48 AM
Sager222
Mar 13, 2014 02:04 PM
ChristopherN
15
Dec 29, 2011 07:58 AM
mdwilli
Apr 21, 2009 10:25 PM
audimaster
Jun 10, 2007 05:08 PM
