Reman IDM?
Old May 3, 2011 | 07:15 AM
acwd1950's Avatar
acwd1950
Reman IDM?
Has anyone used a reman IDM? There is a place on Ebay that has them for 139 dollars. I ran a buzz test on my truck the other day and they all sounded the same but at the end of the test I got a code P1298 IDM fail. On the cylinder contribution test I got two codes P0275 Cylinder 5 Balance and P1670 EF feedback not detected. Talked to the Ford dealership and the service manager told me that the IDM was bad and that he had seen IDMs fail and create a miss? Replace the IDM and that would fix my problem. Anyone else had this problem? Or is there something else I need to be looking for?
Steve
Old May 3, 2011 | 07:36 AM
Izzy351's Avatar
Izzy351
Have you ruled out the UVCH or the wiring between the IDM & engine? They are much more common failures...
Old May 3, 2011 | 07:49 AM
acwd1950's Avatar
acwd1950
I had the VC off and done the clip mod and re torqued the rockers and injectors. One side had a new harness under the VC on the pass side I think. The book at the dealer said the P1670 code to check wires? but I didnt get it wrote down. Should have made a copy of it.
Steve
Old May 3, 2011 | 07:53 AM
acwd1950's Avatar
acwd1950
Is there a place on the net to look up the codes and what to check? Dont like driving to town to look at the book.
Old May 3, 2011 | 09:17 AM
mueckster's Avatar
mueckster
Look at this before you condemn the IDM:
GB Tech Bulletin 103 Ford IDM Module Replacement[1][1].pdf
Old May 4, 2011 | 07:06 AM
acwd1950's Avatar
acwd1950
Thanks Roland I will do that test this weekend.
Old May 9, 2011 | 07:19 AM
acwd1950's Avatar
acwd1950
Ok Roland, I tested the wiring as shown in the bulletin. Got all 2.1 ohms on right bank, 2.4 to 2.9 on the left bank. It passed test 2 and 3 also. Anything else to test before I shell out the greenbacks for a IDM?
Thanks
Steve
Old May 9, 2011 | 08:26 AM
mueckster's Avatar
mueckster
Other than swapping in a known good IDM, you've pretty much narrowed it down. Do you have an early or late '99?
Old May 9, 2011 | 08:35 AM
acwd1950's Avatar
acwd1950
It was manufactured on 11 98 so its a early 99?
nomad221
May 10, 2012 03:24 PM
DZL_DK
18
Sep 21, 2008 10:29 AM
TopThis8899
Sep 28, 2007 07:48 PM
dchaney71
Dec 18, 2006 09:56 PM
tjbeggs
Jan 31, 2006 06:00 AM
