'nother IDM thread
Old May 9, 2012 | 08:42 PM
nomad221's Avatar
nomad221
'nother IDM thread
My IDM quit three days ago. Purchased a 120 to replace my 100 on ebay and it is throwing a P1668 code, commo between IDM and PCM is bad.
I have continuity tested all wiring between the PCM and IDM, checked power and grounds, everything is good.
Is there anything else I can do ?
Old May 9, 2012 | 09:09 PM
pjwoolw's Avatar
pjwoolw
Might just be the fuse or the relay. My bet is on the relay.
Borrowed this from Rick.
FJ1 DIAGNOSTIC TROUBLE CODE (DTC) P1670 and P1668
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
Open fuse
IDM relay
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM powering circuits
PCM
Check for other codes.
Key on, engine off.
Perform KOEO On-Demand Self Test and retrieve Continuous DTCs.
Was DTC P1668 present?
Old May 9, 2012 | 09:10 PM
oldbird1965's Avatar
oldbird1965
How did you know it was the IDM that failed? I'm sure you checked all the pins on the connection? Maybe the flebay's wasn't any good? Check all the fuses, sorry I don't have anything else.
Old May 9, 2012 | 09:11 PM
oldbird1965
You beat me Pete! Your info is better though.
Old May 9, 2012 | 09:34 PM
pjwoolw's Avatar
pjwoolw
LOL It's Rick's info I just borrowed it!
Old May 9, 2012 | 09:52 PM
nomad221's Avatar
nomad221
Checked everything Glenn. Power and grounds are good. No p1670 code.
Paid overnight shipping too. Seller only offered to ship another one ground from FL. Asked them to ship 2 day. No bueno.
I'm livid..
Old May 10, 2012 | 02:09 AM
glovemeister's Avatar
glovemeister
Let me guess you purchased from Pensacola diesel?
I purchased an IDM from them and haven't installed it yet. This thread reminds me that I need to, so I can find out if it will help me.I purchased a modded idm from a member on another website. If I had to guess I would say throttle response was lessned and it also threw codes aka was garbage.
Old May 10, 2012 | 01:21 PM
nomad221's Avatar
nomad221
Yup, Pensacola Diesel. I'd be interested to read if yours is junk also. My truck will not start. No commo between PCM and IDM.
Old May 10, 2012 | 03:08 PM
yoslick's Avatar
yoslick
Just got a 120 from them bout 2 weeks ago so I could mod my original when I have a chance, so far no problems, works great!! ??
Old May 10, 2012 | 03:24 PM
glovemeister
I'll throw it in later today and see what happens. If I had to guess I'd say they sent you a bonk idm.
johnarahill
Aug 22, 2013 07:26 PM
mrjones111
1997 - 2003 F150
Jul 24, 2013 12:33 PM
Napewastewin
Apr 14, 2011 05:34 PM
wadecamp
Mar 24, 2008 11:04 AM
UcaN
Apr 23, 2007 07:37 PM
