No Power!!
Old Mar 23, 2011 | 02:29 AM
utracefan's Avatar
utracefan
No Power!!
Just bought a 2004 F-250 and as soon as the turbo starts to spool I loose ALL power! It act like a Gas engine when the exhaust is plugged. No smoke, no codes. Flat highway only 55mph, hills only 25 and this is un loaded. I was told the turbo was bad any other suggestion???
Thanks
Tim
P.S New to the forum and new to Diesels
Old Mar 23, 2011 | 10:42 AM
rdunagan's Avatar
rdunagan
could be multiple things not just the turbo. there are some guys on here that will tell you what to do and what to check to see what it could possibly be. hopefully they will chime in soon!
Old Mar 23, 2011 | 11:00 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Do those tech that are now working and should come on after work a favor and get your trouble codes pulled and post them to help with their diagnoses.
Old Mar 23, 2011 | 06:46 PM
cheezit's Avatar
cheezit
check it for codes. check the map hose for damage and blockage. remove and check the egr valve and see if its all carboned up and hung open.
loosen the 2 15mm nuts on the down tube to the cat and drive it. if that helps a bunch you have a pluged cat.
also look at ficm voltage, icp and icp voltage. look at icp and ipr at hot idle (185*) with the ac off.
check fuel pressure
check fuel filters
check oil level
Old Mar 23, 2011 | 07:23 PM
cartmanea's Avatar
cartmanea
If you hold the throttle wide open from a stop, does it come alive above about 2300 rpm? If so, your turbo vanes are probably sticking open. You can verify this by unplugging the VGT actuator and seeing if it performs the same.
Old Mar 23, 2011 | 07:49 PM
bismic's Avatar
bismic
There is a troubleshooting thread in the Tech Folder on "low power".
Old Mar 23, 2011 | 08:05 PM
utracefan's Avatar
utracefan
There is no codes. Looks like it has a new turbo and down tube. I an checking the egr now
Old Mar 23, 2011 | 08:09 PM
cartmanea's Avatar
cartmanea
Did you scan with something that will read the Ford-specific codes? A generic OBDII reader won't see a lot of them.
Old Mar 23, 2011 | 08:12 PM
utracefan's Avatar
utracefan
It was just a code reader. The light on the dash isn't on
fi I give it gas it tries to spool but looses power. The turbo looks new. Can I remove the egr and re use the gasket
Old Mar 23, 2011 | 08:15 PM
cartmanea's Avatar
cartmanea
What do you mean it tries to spool?
Old Mar 23, 2011 | 08:50 PM
utracefan's Avatar
utracefan
it sounds like the turbo starting to wind up (spool). at a dead stop in drive wide open throttle it won't get over 2600 rpm. I pulled the egr and it looked new but it made a rattle noise like something was loose inside. the intake looked ok I scraped the inside and there was a little carbon but not what I was expecting. I pulled the map and when I looked inside the hose it was clean. Looked like the quy before me spent alot of money trying to fix it. I'm not getting hardly any black smoke not enough fuel? I did replace both filters today and no help.
Old Mar 23, 2011 | 09:01 PM
bismic's Avatar
bismic
The EGR valve rattle is normal. Re-using the gasket is most likely fine.
Old Mar 23, 2011 | 10:38 PM
cartmanea's Avatar
cartmanea
Inspect your intercooler piping boots, you could have a cut in one. Also, check around the up-pipes for soot around the firewall indicating an exhaust leak. Either of those can make a whistling sound, which could be what you think is the turbo trying to spool, and cause lack of power. Also, might be good to pull the intake piping off (with it not running) and check the turbo inlet to make sure it looks good and spins freely.
utracefan
Mar 27, 2011 09:04 AM
Tim J
47
Aug 3, 2008 10:45 AM
twp
1997 - 2003 F150
Jan 11, 2008 01:25 PM
Tim Young
Jan 23, 2006 07:40 AM
86lx
Apr 22, 2005 09:48 AM
