ip intall??
Old Mar 16, 2011 | 11:08 PM
  #61
84-6.9L's Avatar
84-6.9L
It has stayed above 1200 for no more then about 5sec. But pulling the tractor its hovers between 900 and 1050 at 55
Old Mar 17, 2011 | 10:12 PM
  #62
Coalroller's Avatar
Coalroller
where is your pyo located at 84?
Old Mar 17, 2011 | 11:00 PM
  #63
84-6.9L's Avatar
84-6.9L
Right after the right exhaust manifold on the turbo up pipe.
Old Mar 17, 2011 | 11:11 PM
  #64
wreckinball's Avatar
wreckinball
wow so yeah at 1200, you are scorching in the cylinder.
Old Mar 18, 2011 | 09:22 AM
  #65
84-6.9L's Avatar
84-6.9L
Not nessesarily. Sure the exhaust gets hot because it only gets the hot gasses. The piston can handle more heat then you think because it cools slightly with the fresh air charge and that piston is not at the same temp as the exhaust gasses. When i took it apart there was no evidence of scorching our melting. I'm not saying it is good for it but i think it can take it. The few times we have had pyros in our pulling tractors as soon as you leave the line the pyro pegs at 1600 and stays there til you idle them back at the end. I know it cant be good for them but we have never stuck a piston. I've never seen a melted piston the real danger is sticking a piston and that happens when they get hot and expand in the cylinder and the tollerances get to tight. I've seen manifolds so hot you could see right through them and the pistons are just fine but those have been honed out to be loose to allow for expantion.
hondarider10
Jun 3, 2012 02:44 AM
bio-d
Oct 24, 2011 10:55 PM
LSO1123
Aug 4, 2011 09:01 PM
Wookie35
Feb 26, 2009 09:29 PM
fatdaddy
Exhaust Systems
May 23, 2003 06:24 PM
