ip intall??
Old Mar 12, 2011 | 11:09 AM
snaponprofile's Avatar
snaponprofile
ip intall??
Hey guys, I'm installing my new ip and I'm wonering how tight the 3 mounting bolts need to be? I couldn't get to the pass. Bottom bolt with my wrenches so I tapped the bolt tight with a long screw driver and hammer. It seems tight but how tight does it need to be so it won't leak? Thanks, I'll post pics later.
Old Mar 12, 2011 | 12:10 PM
Otahyoni's Avatar
Otahyoni
When i put mine on i used the german specs.......
"Gootentite"
My '93 FSM say 25lb-ft
Old Mar 12, 2011 | 12:15 PM
snaponprofile
"Gootentite"
how did you get it tight??
Old Mar 12, 2011 | 12:22 PM
wreckinball's Avatar
wreckinball
Strapon, if you have a grinder, grind down the box end of a box end combo wrench and then snip off the open end with a cutoff. You will have no prob getting to them with this, and you'll need it again.
Old Mar 12, 2011 | 12:26 PM
Otahyoni's Avatar
Otahyoni
Maybe its the way mine is set up, but i used a plain old craftsman 9/16" wrench....
Old Mar 12, 2011 | 12:27 PM
Coalroller's Avatar
Coalroller
wreck not sure if you know lol but you called him strapon.... I had to read a few times just to make sure thats what it said
Old Mar 12, 2011 | 12:35 PM
wreckinball
Bwahaha stupid iPhone. Lmao. I hope that doesn't happen again, depending on what's said that could be akward. Sorry bro lol.
Old Mar 12, 2011 | 12:42 PM
snaponprofile
I ground down a old 9/16 wrench I had but when I tightened it one of the forks bent. I think I'll try grinding one of my combos like you said though, hopefully that will work. Wreck, did you have any leaks after the swap?
Old Mar 12, 2011 | 12:46 PM
snaponprofile
Pics...
Old Mar 12, 2011 | 12:48 PM
wreckinball
The seal happens at the oring but if it's not held tight it will cause larger problems than a leak. Things like a dead pump real fast. No I don't get leaks there but I crank mine really tight. The combo will work and stay strong mine is like 1/8" thick
Old Mar 12, 2011 | 01:05 PM
snaponprofile
Oh boy, ok. I'll have to make one of those and try to crank it tight. You totally grind off the open ended side and grind off 1/2 of the closed end side?
more pics...
Old Mar 12, 2011 | 01:07 PM
snaponprofile
Also, how do you adjust the timing?
Old Mar 12, 2011 | 01:50 PM
wreckinball
No you grind down the box end side so it is thinner. Leave it boxed, just thin it. Yes to cutting off the open end side. There is a perfect vid on YouTube but it's passenger side to advance and drivers side to retard it. Start with the line on the pump lined up with the top line of the housing. Then you will want to go approx a dimes width to the passenger side.
Old Mar 12, 2011 | 03:13 PM
snaponprofile
So you're basically just rotating the pump it self?
Old Mar 12, 2011 | 03:44 PM
johnboggs21's Avatar
johnboggs21
when I adjusted my timing, I took the high idle solenoid off to get to the one bolt, and cut the end off one of my cheap wrenches and welded it back on at an angle. All the other bolts I was able to use a regular wrench on...
