ip intall??
Old Mar 16, 2011 | 07:24 AM
  #46
snaponprofile's Avatar
snaponprofile
Oh yeah. Mine jump 10psi in a sec.
Old Mar 16, 2011 | 03:59 PM
  #47
wreckinball's Avatar
wreckinball
Ain't it fun!! I love pulling up to the newer trucks and turning heads with the sound alone !! Putting my turbo on made me fall in love all over again. We still have our lovers quarrels but my truck and I are mated for life! Lmfao
Old Mar 16, 2011 | 05:08 PM
  #48
snaponprofile
Too much fun! I love cooking ricers all day no problem, haha.
Old Mar 16, 2011 | 05:11 PM
  #49
FORDF250HDXLT's Avatar
FORDF250HDXLT
i hope you guys get this out of your systems soon so you can provide what the overall fuel economy increase is.
i'll keep waiting.probably another couple months by the sounds of how much fun your having lol.
Old Mar 16, 2011 | 06:04 PM
  #50
snaponprofile
You should buy jamy duty's turbo.
Old Mar 16, 2011 | 06:09 PM
  #51
Coalroller's Avatar
Coalroller
Originally Posted by 84-6.9L
I suppose it would make a difference being you are wastegated? It takes a lot to get mine over 1100 because it just makes more boost so the extra air I'm thinking keeps the egts down.
what kind of boost numbers are you making? Once in a great while ill hit the 17psi mark when towin heavy up a grade (i know its bad for my head gasket but it is literally once in a GREAT while it helps with gettin the load over the hill, ill turn the wastegate back down after the new pump and ip go in) and i am right about the 1050* mark
P.S. i can hit that mark quick or slow depending on the position of the go fast peddle
Old Mar 16, 2011 | 06:11 PM
  #52
snaponprofile
Now that I turned the pump down I can only hit 700* empty.
BTW: do the glowshift boost gauges read slow?
Old Mar 16, 2011 | 06:16 PM
  #53
Coalroller's Avatar
Coalroller
thats a good temp to stay around for empty... is that peddle floored?
Snapon where is you line tied in at? Pics would help if you got them, cause with the ats system you can T the gauge in to the wastegate line or the snail shell, one is a little faster than the other imo
Old Mar 16, 2011 | 07:20 PM
  #54
snaponprofile
Pedal to the floor, yes. Tranny went up to 190* today. Boost gauge is faster than I thought, I gunned it a few more times and it jumps fast, I just thought it seemed slower at first.
Old Mar 16, 2011 | 08:08 PM
  #55
Coalroller's Avatar
Coalroller
gotcha... sounds like your all set man
Old Mar 16, 2011 | 08:27 PM
  #56
84-6.9L's Avatar
84-6.9L
Ive only hit 11 but it takes a long hill at 24,000gw before it hits 1300. Its quick to 1000 the slowwwwly builds after that
Old Mar 16, 2011 | 08:39 PM
  #57
Coalroller's Avatar
Coalroller
id say if you can help it do your best to not hit 13!!!!!! 1250 is the pushin it number... pistons tend to not do so well at those temps
Old Mar 16, 2011 | 09:09 PM
  #58
wreckinball
depends on where the pyro is installed as well. i would slam the brakes if i hit anything over 1150 where mine is at. 1300 will melt an idi not turbo piston. When the turbod them, they had the better pistons. caregul with high number like 1300. I can still see 800 but it is pedal to the floor and going up a section of nearly 14% grade at 60 mph.
Old Mar 16, 2011 | 09:45 PM
  #59
BlueOvalBud's Avatar
BlueOvalBud
AMEN!!!!
Old Mar 16, 2011 | 09:56 PM
  #60
snaponprofile
Here too, here too.
