Replace ECC on 89 E150 5.0 HELP
Old Mar 14, 2003 | 07:06 PM
MsLynch's Avatar
MsLynch
Angry Replace ECC on 89 E150 5.0 HELP
Can anyone tell me how to remove the ECC which is located passanger right side. I need to replace it. Thanks
Old Mar 14, 2003 | 07:46 PM
steve83's Avatar
steve83
I'm not familiar with vans, but on trucks, you just pull the connector (10mm bolt in center) and the 2 nuts, and then slide it into the engine compartment & out.
Old Mar 14, 2003 | 08:24 PM
E150X's Avatar
E150X
Computer in my 91 van is inside, passenger side, by your feet. Why do you need to replace it?
Old Mar 15, 2003 | 12:07 PM
E150X's Avatar
E150X
Are you asking about ECU or EEC?
Old Mar 15, 2003 | 06:00 PM
steve83's Avatar
steve83
What's the difference? Electronic Control Unit (ECU) = Engine Electronic Control (EEC) = Powertrain Control Module (PCM) = Motronic Control Unit (MCU) = "the computer", right? Ford has used all those names for basically the same part. I guess you could call it the Engine Control Computer (ECC) if you want...
Old Mar 15, 2003 | 06:22 PM
E150X's Avatar
E150X
Smile Replace ECC on 89 E150 5.0 HELP
Hey Steve83, would it be better to use a later model truck ECU or the older Mustang computer for converting to Mass Air? Don't know when Ford went to OBDII or if they connect to older connection blocks. Haynes manual doesn't show it. Any ideas? Thanks in advance!
Old Mar 15, 2003 | 11:26 PM
steve83's Avatar
steve83
I always use the EEC that goes with the engine I'm using. The easiest MAF conversion IMO (and certainly the easiest to maintain & repair) is putting an OE MAF engine COMPLETE into your vehicle. That way, you can look in the same manual everyone else uses to work on it, and you can even find how to install it. That's what I did to my truck and a friend's '75 Bronco, both of which you can see in my signature link.
Old Mar 16, 2003 | 01:03 AM
E150X's Avatar
E150X
That's a good idea. Cooked the engine in my van last month. Mechanic said previous owner /carlot had wired oil pressure gauge to read high when really not much there. Found a 2000 Exploder 5.0 w/28k miles then orderred a conversion kit but it went on back order again. Thought about using the Xpl ecu cause I have the complete harness but can't find a Helms manual yet. Already have info on the Mustang. What do you think?
Old Mar 16, 2003 | 02:16 AM
old65's Avatar
old65
Question Replace ECC on 89 E150 5.0 HELP
ford motorsport makes a kit to convert earlier 5.0 cars to mass air-possible to use here? may be worth looking into-dave-
Old Mar 16, 2003 | 02:22 AM
steve83's Avatar
steve83
Get a Ford (Helm) CD off eBay instead of the paper Helm. $6 vs $40
ktm4012
Jul 5, 2016 11:23 AM
1990f2505.8
18
May 27, 2016 08:17 AM
Shane Carruth
57
Apr 3, 2016 07:41 AM
choate
Apr 16, 2015 11:10 PM
lcadwallader
Aug 18, 2001 06:31 PM
