Hello everyone. I have been doing some research because i'm wanting to change the PCV valve on my 1993 351w. This image has a great picture of what it looks like. My question is do I simply loosen the hose clamp, pull it off there from hose 6A666, then pull it off the other hose 381188 and replace or does all that have to come off?
I had to pull the upper intake to change the PCV on my old 1992 F350 w/5.8l engine.
I'm thinking I can go in there left handed and do it in 30 min or less. I hope. I can do little stuff and this doesn't look too bad. I can see mine. I think.
If it takes more than 2 minutes your slacking off on the job….
