stacking chips
Old Dec 23, 2010 | 02:00 PM
c.wathen's Avatar
c.wathen
stacking chips
has anyone tried stacking a ts 6pos chip with another chip? is it possible?
Old Dec 23, 2010 | 02:17 PM
Ziggy.'s Avatar
Ziggy.
You could, but it would be a waste of time. You are much better off having that TS chip custom burnt for your truck. Or spending that money on a DP tuner or another tuner that will do more for your truck than stacking chips and be much better on your motor as well. Do bother fooling with trying to stack chips.
Old Dec 23, 2010 | 03:36 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If you want to get technical.....
You CANNOT stack a "chip" with another "chip". It is physically impossible to place more than one piece of external memory on the PCM at one time.
These are examples of a chip for our 7.3L diesels:
This is where each of the above "chips" are installed:
These ARE NOT "chips":
This is where the above items install. All they do is fool the injection control pressure sensor input to the PCM.
These are also NOT "chips":
This is where the above items are installed:
Hope this helps.
Old Dec 23, 2010 | 11:25 PM
c.wathen's Avatar
c.wathen
i couldnt see your last pic but imma assume the other items u said not chips(programmers) connect to the dlc. so let me rephrase my question, can you stack a chip and a programmer. im still learning light duty diesel high performance so be patient, they dont teach that at nashville auto diesel college yet, just heavy duty diesel, so thanx.
Old Dec 23, 2010 | 11:40 PM
Pocket's Avatar
Pocket
On these trucks, no.
A chip will override the memory on the PCM. So if a programmer is installed on the PCM, it will be ignored by the chip and overridden entirely.
Old Dec 24, 2010 | 01:27 AM
Izzy351's Avatar
Izzy351
Like Curtis said, not on these trucks. The chip handles everything -- fueling, timing, & shifting. Using a programmer will only be overridden, and anything else like ICP foolers are completely uncessesary as well. Just pick a good tuner and proceed. If you have a 6-position chip, Tony Wildman will reburn it for $150 with awesome tunes, and on top of that, if you need any re-burns, they're free. I'm quite happy with his tuning, and so are many others.
On the Cummins, you HAVE to stack. One box for fueling, one for timing, which has to do with legal issues rather than technical. Kind of dumb really, but you know what happens when lawyers get involved...
powerstroke cowboy
Dec 18, 2011 11:37 PM
stroken
62
Jan 20, 2011 11:44 AM
akascutter
20
Mar 10, 2009 01:08 PM
Oversize
Feb 23, 2009 03:35 PM
TDCsuperduty05
Mar 14, 2005 01:15 PM
