Stacking chips
Old Mar 1, 2008 | 11:04 AM
stroken's Avatar
stroken
Stacking chips
My buddy asked me if I would ever stack my chips. I told him now. He asked why not, and I was stumped. What are the plus' to stacking a chip and what are the down sides. I have a dp tuner now. thanks guys
Old Mar 1, 2008 | 11:45 AM
Pocket's Avatar
Pocket
DP-Tuner is all you need. Stacking anything else is completely useless.
If you try to stack with a programmer, the DP-Tuner chip will override whatever the programmer is trying to do. So that turns out to be an un-stackable combo.
If you try to stack an ICP box such as the Edge EZ, Banks 6-Gun, etc, then those will only call for more ICP than your HPOP can handle. The DP-Tuner chip already has ICP tables programmed in the tuning, so bumping it up higher won't do any good. In fact, you might see more smoke and a drop in power at WOT on higher chip settings. So again that turns out to be a bad combo as well.
Stacking is old technology for the PSD that has no use with current chips. Everything can be controlled from a single unit, and with better precision.
Old Mar 1, 2008 | 12:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Which buddy?
Old Mar 1, 2008 | 10:59 PM
stroken's Avatar
stroken
He just got his learners, names Kyler.
Old Mar 2, 2008 | 12:36 AM
Power_Hungry's Avatar
Power_Hungry
Former ******
The only chips that are stackable are Pringles.
Like pocket said, in the performance world you do not stack chips & programmers or chips & ICP modules. I guess you *COULD* stack a chip OR a programmer with an ICP module, but in most cases you actually end up with less power and marginal drivability. Pick you poison, but only pick one.
Take care.
Bill
Old Mar 2, 2008 | 05:28 PM
ts_stroker's Avatar
ts_stroker
i have 2 stacked on mine and i'm u can tell a BIG difference in the 2 together and one by itself. but i have them tuned into eachother also
Old Mar 2, 2008 | 06:47 PM
Power_Hungry
Former ******
I did say in most cases... Obviously there are cases where they do work, especially when in tune with each other. Good to hear your setup is working well for you.
Old Mar 3, 2008 | 05:10 PM
ts_stroker's Avatar
ts_stroker
yea it works real good all i gotta do it get a clutch to hold it bc the stock on slips on the dyno badly but that was my numbers with the stocker in it
Old Mar 3, 2008 | 05:30 PM
PowerstrokeJunkie
The steroid is nothing more than a fancy 18k mod. There's much better out there for you TS stroker.
Old Mar 3, 2008 | 11:07 PM
Pocket's Avatar
Pocket
The tuning on my chip calls for way more ICP pressure than the TS chip and Steroid stacked together can get you.........
Old May 31, 2008 | 11:56 AM
bigmack.81's Avatar
bigmack.81
Dude Dp tuner hardly does anything. It only gives 140 RWHP.
Old May 31, 2008 | 12:01 PM
Superduty krazy's Avatar
Superduty krazy
It only gives you a 140hp with out breakin into anything else a cheap way to move a little faster
Old May 31, 2008 | 12:09 PM
bigmack.81's Avatar
bigmack.81
Chip
Guys I need to know the biggest, badest chip that I can buy for A '00 7.3L.
Old May 31, 2008 | 12:11 PM
bigmack.81's Avatar
bigmack.81
no abbriviations please!
Old May 31, 2008 | 12:43 PM
rbaker6336's Avatar
rbaker6336
what mods have you done ?
if you are basically stock a good 120hp will probly be more than you need
