S. California Chapter Join Chapter, Leader:
December All Topic
Old Dec 12, 2010 | 01:24 PM
  #166
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by SteveBricks
Lots of passes left in those things...
So what did they set you back?
Old Dec 12, 2010 | 01:33 PM
  #167
FORD RANGER's Avatar
FORD RANGER
due tell steve!
Old Dec 12, 2010 | 01:48 PM
  #168
SteveBricks's Avatar
SteveBricks
FTE Emeritus
Originally Posted by bpounds
I would have grabbed the alum wheels. When you said 5 spoke, I was expecting steel like mine.
This tire/wheel combination only weighs a little over 61 pounds. The ProComp 17x9/BFG 315/70 combo I have on there now is pretty close to 80 pounds. Should help the truck get off the line a little quicker.
5 bills and a 1 1/2 hour round trip.
Old Dec 12, 2010 | 01:57 PM
  #169
bpounds's Avatar
bpounds
Did you get the lugs and center caps?
Now you will need to adjust to the new lap times.
Old Dec 12, 2010 | 02:13 PM
  #170
SteveBricks
FTE Emeritus
No lugs, no center caps...though I wouldn't have used the caps on the front anyway because I like to manually engage the hubs when racing. Should be able to pick up some lugnuts pretty easily if I have to.
I'll be out to Irwindale a couple times before the season opens to get a feel for things...shouldn't be too tough to make the necessary adjustments. No tougher than before, anyways.
Old Dec 12, 2010 | 02:18 PM
  #171
FORD RANGER
you should steve. the lugnuts that is.
Old Dec 12, 2010 | 03:16 PM
  #172
sddesigns's Avatar
sddesigns
FTE Emeritus
Whats the weight to time ratio, 100lbs=.10sec?
Old Dec 12, 2010 | 03:21 PM
  #173
FORD RANGER
should be alittle quicker.
Old Dec 12, 2010 | 03:33 PM
  #174
SteveBricks
FTE Emeritus
For rotating mass vs. dead weight I've heard figures ranging from 1lb = 7.5lbs to 1 lb = 10 lbs. I don't know if 100 lbs of dead weight equals .1 sec or not.
So theoretically if I'm saving say, 72 pounds of rotating weight that could equal up to the equivalent of 720 pounds of dead weight over the old tire/wheel combo. There's no way that'll make the truck .72 faster in the quarter, but I think between that and it's being a shorter tire (30.5" instead of 34.5") it's realistic to expect 2 or 3 tenths.
I suppose if I really wanted to try to figure it out this might help: http://www.mcasco.com/p1rdy.html
But that stuff makes my brain hurt
Old Dec 12, 2010 | 03:41 PM
  #175
sddesigns's Avatar
sddesigns
FTE Emeritus
Yea, I can see the tire making more of a difference due to size than weight.
If you lighten up the total weight, lets say 400lbs, is there a formula for speed in a consistent run at the higher weight?
Old Dec 12, 2010 | 03:44 PM
  #176
FORD RANGER
you know i was told a while ago that a shorter tire will lower you gear ratio slightly. i don't know if its true or not. they have one for stock car racing i have a couple of books with that formula in it. for drag racing i have no idea.
Old Dec 12, 2010 | 03:45 PM
  #177
SteveBricks
FTE Emeritus
You can plug numbers in to the mph/weight calculator and fiddle around: Automotive Calculators offer to you by Ford Trucks Enthusiasts
They're pretty accurate, but there's so many variables that nothing's gonna give you dead nuts figures. Kinda fun to play around with though.
I don't think the calculator here on FTE takes drive train loss into consideration, so the HP figures are probably high by about 20%.
Old Dec 12, 2010 | 04:00 PM
  #178
bpounds's Avatar
bpounds
I suggest we all go visit a mid-west chapter and advise them that it is 85 degrees warm here in So Cal.
Old Dec 12, 2010 | 04:04 PM
  #179
SteveBricks
FTE Emeritus
Hell yes... I think I will!
Feel free to take this along on your trip:
  #180
FORD RANGER
yeah thats kind of hard to do. but it gives you some idea of what your looking for tho.
