Speedometer drive gear help
Old 11-29-2010, 03:44 PM
TBTRUCK's Avatar
TBTRUCK
TBTRUCK is offline
I have a 1951 F-3 ford truck. The speedometer drive gear is worn round at the cable entry. I have not been able to find a replacement gear.
The number on the old gear is 01T-71/A-18.
Does anyone have a suggestion????
TBTRUCK
Old 11-29-2010, 07:06 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,467 Likes on 1,407 Posts
Just for clarity and to make sure we're all on the same page, we're talking about the speedometer drive gear inside the transmission, attached to the main shaft, not the driven gear on the end of the speedometer cable?
Old 11-29-2010, 08:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Welcome to the forum!
I'd bet you mean the driven gear. What trans do you have, a crashbox 4-sp? The end where the cable attaches is hollow tube that is punched/crimped to square to accept the cable. If the cable gets old and hard to turn, the torque required starts to round out the tube.
So you can repeat what the factory did - carefully - and that is crimp it back to a square shape. New ones? Not sure for the early trucks. You can try the usual suspects (Dennis Carpenter, C&G, etc) or Mac Van Pelt (Ford Flathead Engines - VanPelt Parts & Service) who specializes in old Ford trannies.
edit: I believe the piece you want is a 01T-17271-A, which has 18 teeth. That's if you have the 4-sp, but have whoever you buy from confirm.
Old 11-29-2010, 09:08 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Great point Wayne! I'm thinking since he's talking about out by the cable end - the part that inserts into the transmission, he's talking about the "driven" gear as Ross pointed out.
Here's my suggestion. If you have a speedometer shop close by, it might not be a bad idea, for $30, to have them make you a new speedometer cable with appropriate driven gear installed.
The reason I mention this is because if the gear shaft is that worn, chances are the cable is stressed as well. And it would be a real pain to install a new gear and then have the weak part of the cable snap.
As easy as these are to install, and the low cost ($30 for a new one) it's kind of a no brainer!
Welcome to FTE by the way!
Old 11-30-2010, 12:13 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Best speedo cable supplier I've found is Antique Auto Supply, Arlington Texas. 1-817-275-2381
He sells one (yes, it's Taiwanese) that is the correct length, has the correct fittings, and is in a nice metal spiral sheath instead of the plastic tube most modern ones have. Much more flexible and price is very good too. Many of the ones sold for 48-52's are actually for 53 - 56's and don't connect to the speedo head correctly.
Old 09-29-2012, 08:17 PM
51M1's Avatar
51M1
51M1 is offline
My turn. My driven gear in the tranny is rounded out. Cable is good (new), speedo good (was siezed but I fixed it) Cable wont turn when truck is driven. Can this drive gear be replaced easily and how is it done? the little one on the top rear of the tranny where the cable is attached.
Thx in advance.
Old 09-29-2012, 08:35 PM
r_reed's Avatar
r_reed
r_reed is offline
my tranny is a Heavy Duty 3speed. i believe i found a listing by part number in the job lot automotive catalog back in 2008. i ended up finding one in a local early ford v8 parts store (used). point is, job lot had a new one for mine, will maybe have one for yours too.
Old 09-30-2012, 10:49 AM
51M1's Avatar
51M1
51M1 is offline
Flathead Parts Drawings-TransmissionsJustfound all the tranny diagrams online.
Looks like the drive gear is held in with a spring clip. Going to take a look.
r_reed... how much do you want for your extra drive gear?
Thx Rick
Old 09-30-2012, 12:31 PM
r_reed's Avatar
r_reed
r_reed is offline
rick, i didn't order the gear from job lot, because i found the local used one. i don't have an extra. mine did have a part number stamped into it and i found that part number at job lot. it's much nicer to work on it if you have the tranny in the cab removed. the reason i needed a new one is that the speedo cable was slipping inside the gear: even a new cable. once i got a diff gear, no problem. good luck. dick r
Old 09-30-2012, 12:55 PM
51M1's Avatar
51M1
51M1 is offline
TThx. R_reed. I will check them out.
Anyways i got it going.
7/8" wrench to get the gear out. I think i have the heavy duty 3 speed.
picture of the gear... The hole was completely rounded. Mine has 22 teeth.
And the fix as suggested carefully with a ball peen hammer.
dlfulp
08-12-2016 04:23 PM
NDFordman
03-16-2016 06:42 PM
Randle
09-18-2015 08:23 PM
BiltFordTuff
07-23-2011 04:53 AM
jowilker
06-01-2001 09:41 AM
Quick Reply: Speedometer drive gear help
