steering shimmy
Old Sep 29, 2012 | 12:09 AM
kenjh's Avatar
kenjh
steering shimmy
ok ..I have new tires up front ..balanced ..lug nut's are all there and tight ..all the bolts are tight ..tie rods drag link are good and greased ..at about 30 to 35 miles an hour ..it will sometimes start to shudder the steering will hammer left and right ....hitting the brakes or driving left and right ,,hard ..will stop the shudder ..what am I missing ?? oh ,,and yah this is a Marmon 4X4 with the stock front end nothing is loose ..that I can find ..and because of the stock wheels ,,no one will touch it ..so I have to learn how to fix this myself ..any idea's??
Old Sep 29, 2012 | 12:33 AM
fordman75's Avatar
fordman75
I'm not familiar with the front diff in your truck. But have you checked the ball joints or king pins ( which ever it has ) . And how about the front leaf spring bushings?
What you are describing is what's commonly called "death wobble".
Old Sep 29, 2012 | 12:57 AM
kenjh's Avatar
kenjh
on the Harley ..YUP death wobble ...in the truck ..more of the washboard dance ..but yah hammers back and forth ..hard !!
Old Sep 29, 2012 | 05:02 AM
52'F-3's Avatar
52'F-3
I've found many reasons for this, working on lots of 4x4's. I'm sure with knowledge in the forum you can get it fixed, but sometimes it's not easy.
It can be everything you checked or alittle of all combined. I've found it's a type of occilation that feeds upon itself, usually started when specific conditions are met.
I've found the kinkpins (or balljoint) preload (rotation resistance) along with the steering caster angle are major factors. I'm not familiar with your exact front axle. is it full time 4x4 (does it have hubs?) adding more caster can create unwanted driveshaft vibrations.
if you could post a picture from the side with a wheel off, it would help explain/understand.
Old Sep 29, 2012 | 07:16 AM
petey shoes's Avatar
petey shoes
this is where you call chuck! mine will do the same thing every now and then--but--it's a different axle up front. most of mine is from old tires. make sure your brakes are evenly adjusted, and that one is not "dragging" just a touch.
Old Sep 29, 2012 | 09:53 AM
The Horvaths's Avatar
The Horvaths
Were tires balanced under load?
If all else fails, rotate tires front-to-back. See if symptoms change.
Old Sep 29, 2012 | 10:27 AM
kenjh's Avatar
kenjh
thank's .. I will check the brake ajustment ..try the picture thing ..preload resistance ??the wobble does not get worse with speed .. just as violent at 20 miles and hour and not every trip ...a run down the road can be totally uneventfull or one wobble after another ..there is a friction stabalizer on the steering can it be ajusted ??
Old Sep 29, 2012 | 11:25 AM
teardropty's Avatar
teardropty
I had a problem in my 54 (non 4x4 of course) when I would hit 40-55 mph I would have a shudder that I always attributed to steering but after checking everything out I found the problem. I would brake/turn and the vibration would go away. Of course I didn't realize braking slows things done and turning would also change angle of tires, etc. I though maybe a rotor or brake pad was causing the problem. I checked the wheel bearing hubs. Nothing. And then....
I had the driveshaft balanced and got rid of wheel weights and went to stainless steel tire beads. It took my vibration at certain speeds right away. My F250 has a driveshaft mounted e-brake drum and at speed the out-of-balanced shaft caused issues with that. The wheels/rims had enough oblong that they balanced fine on the spin-machine but when under load they would get out of balance. With the beads, it finds the right spot and made a world of difference. Just my .02 and a different angle to check.
Old Sep 30, 2012 | 09:19 AM
petemcl's Avatar
petemcl
You can probably really light up this problem when you go over highway railroad crossings at speed? Tire size and weight play a part in this also. Preload on the steering box is also important. While you are checking the box make sure that the pitman shaft does not move up and down when you wiggle the tires. If so the box needs an overhaul. As 52'F-3 notes you can adjust the FE with the caster but you can also shim the transmission to compensate if you get driveline vibration. After you find the best combination and you still have the problem if you may want to look at installing a steering stabilizer. Rough Country makes a 2WD version that should work. Maybe someone here on FTE knows another source. This seems like a band aid but it works wonders and can be found as OE on most new truck particularly those with full time 4WD.
Old Sep 30, 2012 | 11:54 AM
kenjh's Avatar
kenjh
railway tracks don't induce the problem..and Rough Country doesn't list ANYTHING as old as our trucks..but nice stuff..still working through your advice thanks guy's ....
Old Sep 30, 2012 | 01:35 PM
theodore/teddy's Avatar
theodore/teddy
Refyred
Kenjh; I'm not familiar with the MH front ends. But I think 52F3 is on the mark. I had the same thing going on with my front end years ago and the dana 44f front axle calls for a 55-70 inch pound preload on the spindle arm bearings (king pin bearings) measured from one of the bearing cap nuts. When I checked mine there was no preload (spindle turned very easy). After replacing the bearings I used shims over the studs between the cap and spindle arm to adjust the preload. This cured my wobbles.
Good luck in your quest.
Bobisnumbah1
1997 - 2003 F150
Jun 10, 2016 07:06 PM
awillo0406
Aug 7, 2014 04:30 PM
stumper1620
Sep 28, 2011 07:05 AM
SHOpar
18
Sep 3, 2008 09:58 AM
doctormap
Jul 2, 2006 05:16 PM
