I have a 2.75 gear ratio with a 19 tooth speedometer gear. I changed to a 3.70 gear ratio, what toothed speedometer gear do we need to switch to so the speedometer works right?
I believe the Ford drive gears (on the transmission's output shaft) come in 6, 7, 8, and 9 teeth. You need to do a little research to find what you have.
If this is a C4 or C6, the speedometer DRIVE gear is made as part of the output shaft.
