Which Speedometer Drive Gear?
Old Jul 19, 2011 | 09:11 PM
BiltFordTuff's Avatar
BiltFordTuff
I have been trying to find a speedometer drive gear because mine is bad, and found it quite hard, I did this speedometer calibration program and entered all the correct information and this is my answer:
Bowling's Speedometer Calibration Program
Input Parameters Are the Following:
  • <CODE>Speedometer Revolutions/mile = 657</CODE>
  • <CODE>Rear Tire Diameter (Inches) = 31.70</CODE>
  • <CODE>Differential Gear Ratio = 4.10</CODE>
  • <CODE>Driven Gear Teeth Number = 20</CODE>
Computation Results:
<CODE>Computed Drive Gear is 5 </CODE>
<CODE>Ratio of Driven Over Drive Gear is 4.0</CODE>
<CODE></CODE>
<CODE></CODE>
<CODE>What does it mean I need???</CODE>
Old Jul 19, 2011 | 09:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is this for the truck in your signature (C6)?
If so, the DRIVE gear is part of the tailshaft and can't be changed. The DRIVEN gear is the one that's on the end of the speedometer cable and can be changed.
The info needed to identify the correct driven gear is trans. model, rear gear ratio, tire size (not diameter), and 2WD/4WD.
Old Jul 19, 2011 | 10:01 PM
shookdaddy's Avatar
shookdaddy
I THINK THAT JEFFS BRONCO GRAVEYARD HAS A CHART FOR THIS MAYBE THIS WILL HELP
Old Jul 20, 2011 | 04:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BiltFordTuff
I have been trying to find a speedometer drive gear because mine is bad, and found it quite hard.
C6
Speedometer DRIVE gear: Made as part of the output shaft, so it is not available by itself.
Speedometer DRIVEN gear: At the end of the cable. 16-21 teeth available.
Old Jul 20, 2011 | 07:03 AM
BiltFordTuff
the drive gear should be able to be changed (it is in the 205 transfer case and not exactly in the C6 trans), me and my dad changed his in his np435 with borg warner transfer case???
Old Jul 20, 2011 | 02:37 PM
NumberDummy
the drive gear should be able to be changed (it is in the 205 transfer case and not exactly in the C6 trans), me and my dad changed his in his NP435 with borg warner transfer case???
There is no Ford part number for a C6 speedometer DRIVE gear simply because there isn't one. 2WD or 4WD makes no difference!
EVERY 1966/97 C6 has the DRIVE gear made as part of the output shaft.
There are DRIVE gears for manual transmissions (NP435, T-18, T-19 and etc), but not for a C6.
Old Jul 21, 2011 | 03:22 PM
BiltFordTuff
well mine is bad which makes my speedometer not work, so what can I do about a non working speedometer?
Old Jul 21, 2011 | 06:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Bill, I think the part BiltFordTuff is looking for is basic p/n 17285. But I'm getting lost trying to find the actual p/n for him.
He has an NP205 transfer case and, according to his original post, he needs a five tooth gear.
But, like I said, other than that I'm lost.
Here is the illustration that shows the gear.
Click on the .pdf link to view.
File Type: pdf
Old Jul 21, 2011 | 10:18 PM
BiltFordTuff
are you saying it is possible to change this gear or would I have to change the entire output shaft??? And would a gear or output shaft work in my 250 4wd (C6 Np205) if it came out of a 150 4wd (C6 Np205)???
Old Jul 21, 2011 | 10:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I'm no 4WD expert by any stretch of the imagination but going by the illustration from the parts catalog the gear is separate from the shaft and can be replaced. As far as interchangeability between F150 & 250 I'll let someone who is more knowledgeable on the subject chime in.
Old Jul 22, 2011 | 11:55 PM
BiltFordTuff
Not to be a nuisance to anyone but I just took my drive gear out pretty easy so just letting you know, you can replace the drive gears
Old Jul 23, 2011 | 04:53 AM
miottimouse's Avatar
miottimouse
so would any one know what color gear to use with bigger tires? as i know my speedo is running slower than road speed i have 350 gears,c6 auto 35x 12.50x15 tires [stock is 235x15] a big difference in size any one figure this out for this size?
David8949
Jul 21, 2016 10:41 AM
Gary Lewis
26
May 3, 2016 09:41 PM
kr514
Sep 24, 2015 10:22 AM
ms_michelle
Large Truck
16
Jan 1, 2012 12:08 AM
truckdocter
May 22, 2011 05:02 PM
