Outer axle shaft seal does not fit
I'm putting new axle shafts in my 01 F350 4x4, so I am using new seals at the same time. The iners go on great, but the outers are such a tight fit that I can't put them on with out destroying the seal.
The seals metal surface that meets the axle shaft is 1/16 or so too small.
Everything Ford or the parts store can get is just like this.
What came off looks like a diffrent style, but nobody knows what it is.
Any ideas before I get the grinder out and make the seal bigger?
EDIT: The trucks SRW and I am doing the front axle shafts
Hmmm...now you guys got me worried.
I just put new u joints on my front axle last night, due to the winter weather advisory issued for my area tonite.
when I pulled out the axle I didn't pay attention to where the metal ring was located.
I just assumed it went on the inside of the rubber seal cause thats how it fit and I didnt see any way to put iton the outside.
I just assumed that it was to keep the rubber seal from collapsing in?? Is this what you guys are talking about?
if you have a bench grinder, make the driver yourself. You need one 1 1/4" x 6" pipe, flange and cap. I forget the closest diameter of flange but you'll need to grind it down to fit into the seal. You will also use the same driver to install the axle into the knuckle.
Here it is sitting properly in the seal:
Useing a wood block just destroys the seal.
