1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Outer axle shaft seal does not fit
Old 11-04-2010, 05:49 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
I'm putting new axle shafts in my 01 F350 4x4, so I am using new seals at the same time. The iners go on great, but the outers are such a tight fit that I can't put them on with out destroying the seal.
The seals metal surface that meets the axle shaft is 1/16 or so too small.
Everything Ford or the parts store can get is just like this.
What came off looks like a diffrent style, but nobody knows what it is.
Any ideas before I get the grinder out and make the seal bigger?
EDIT: The trucks SRW and I am doing the front axle shafts
Old 11-04-2010, 07:26 PM
bill11012's Avatar
bill11012
bump from page two.
Old 11-05-2010, 09:08 AM
bill11012's Avatar
bill11012
Getting it back from page three.
Old 11-05-2010, 11:53 AM
khxor's Avatar
khxor
khxor is offline
What are you using to install the new seal? You need something that supports the inner part of the seal while you drive it on so that it doesn't get destroyed. Any chance you have a picture of the old one that looks like a different style?
Old 11-05-2010, 12:04 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Are you talking about the hub seal that is about 4" in diameter? If so, there is a special tool to install them. I too my axles to the dealership and they did it for free.
Old 11-05-2010, 12:23 PM
Rick03F250's Avatar
Rick03F250
Rick03F250 is offline
Hmmm...now you guys got me worried.
I just put new u joints on my front axle last night, due to the winter weather advisory issued for my area tonite.
when I pulled out the axle I didn't pay attention to where the metal ring was located.
I just assumed it went on the inside of the rubber seal cause thats how it fit and I didnt see any way to put iton the outside.
I just assumed that it was to keep the rubber seal from collapsing in?? Is this what you guys are talking about?
Old 11-05-2010, 12:34 PM
cartmanea's Avatar
cartmanea
I don't know what metal ring you're talking about, can you post pictures?
Old 11-05-2010, 01:01 PM
Rick03F250's Avatar
Rick03F250
Didn't think about taking pics of the job.
It's located behind the wheel bearing assembly.
looks like a retainer but like I said, I thought it was to keep the seal tight to the side of the assembly.
Old 11-05-2010, 05:18 PM
khxor's Avatar
khxor
khxor is offline
There is a grey plastic thrust washer with 4 grooves that goes between the bearing assembly and the seal.
Old 11-05-2010, 05:28 PM
bill11012's Avatar
bill11012
I found out the old and new are the same, its just an update of the same part #.
What does this tool look like and how do I get it?
Old 11-05-2010, 05:36 PM
Zmann's Avatar
Zmann
Zmann is offline
harbor freight has those // if u have a HF?
Old 11-05-2010, 05:49 PM
khxor's Avatar
khxor
khxor is offline
if you have a bench grinder, make the driver yourself. You need one 1 1/4" x 6" pipe, flange and cap. I forget the closest diameter of flange but you'll need to grind it down to fit into the seal. You will also use the same driver to install the axle into the knuckle.
Here it is sitting properly in the seal:
Old 11-05-2010, 05:55 PM
bill11012's Avatar
bill11012
Haha, great. HF is 35 miles away and I was there today.
I will just have to go back.
Whats the tool I am looking for?
Old 11-05-2010, 06:01 PM
bill11012's Avatar
bill11012
Ok, and that will support it so it does not bend?
Useing a wood block just destroys the seal.
Old 11-05-2010, 06:05 PM
khxor's Avatar
khxor
khxor is offline
As long as the flange is flat and you grind it so it does not press against the outer metal ring. You have to hit it hard.
Quick Reply: Outer axle shaft seal does not fit
