The Ultimate Guide on ‘How to Break Your Ford Raptor’
By -
break
Both generations of Ford F-150 Raptors are truly amazing at conquering trails and obstacles that most “normal” trucks could only dream of. That being said, they’re certainly not super-trucks, and even some conditions prove to be too much from time to time.
Much like the  guy in the white H1 Hummer that had to be pulled out by a Ford Super Duty, the driver of this Ford Raptor could’ve used his head a little bit more in order to avoid damaging his truck. According to the video description by, jz 8t0, the Raptor managed to tear apart its CV axle, as well as slice the tire’s side wall. None of those sound like cheap fixes to me. To make matters even worse, the truck had to be towed out quite a distance for it to be fixed, probably creating more damage along the way.
So, here’s your guide on how to break a Ford F-150 Raptor:
  • Don’t survey trail conditions
  • Just “go for it”
  • Floor it when you get stuck
  • Believe you can run over everything
Chime in with your thoughts on the forum. >>
https://youtu.be/b0MOfv7K80I
Jerry Perez is a contributor to Ford Truck Enthusiasts, Corvette Forum, and 6SpeedOnline, among other auto sites.
How to Guides
Read It
Read It
This Hennessey Takes the Expedition Tremor’s Off-Roading Capability to the Next Level
Read It
Read It
