Tire steel belt separation-second time it's happened to me
In December 2021, these Goodyear tires were about 4 yrs old and had maybe 20K miles on them.
I had Discount Tire mount up 4 new Cooper Discoverer AT3 tires since I no longer trusted the Goodyears.
Yesterday, driving north on I45. the steering wheel started vibrating. I exited the interstate and pulled into a parking lot and noticed that my passenger front tire had a steel belt separation like what happened to the Goodyear tire 4 1/2yrs earlier. I had my family with me and it is the middle of the summer here in Houston so I decided to limp the truck home, avoiding the interstate and driving 35mph with the hazard lights on. 12 miles later and we successfully made it home without the tire blowing out on us.
It's raining now and kinda dark outside so it is very difficult to take a decent picture of the bad Cooper tire still on the truck. Here are some pictures:
Like the first time this happened with the Goodyear tire, these Coopers have maybe 20K miles on them.
It's much harder to see the deformed, steel belt separation in this tire but I assure you, it is there. Not near as bad as the Goodyear tire but it is definitely deformed.
My wife was able to see the deformation when we were in the parking lot yesterday. Easier to see in person vs these pictures.
Now that this has happened to me a second time, I'm hoping to get some feedback on what is causing this. Last time it was the driver's side front and this time it's the passenger side front. I keep the tires aired up to about 70-75psi and rotate the tires about every 5-7K miles. I know these trucks are heavy and that has to be causing it, right? BTW, the truck is a single rear wheel, 2-wheel drive and all of my driving is street/highway driving. No dirt roads or offroading.
I tried to do a search on this 7.3L PSD forum and didn't find much.
What information and advice do you have for me?
Impact damage from a very rough road/potholes and high heat/high speed running with a heavy load can cause belt separation. If it was a manufacturing defect, I think you'd see this separation early in the tire's life.
It is hotter than hades here in Houston in the summer. I took a good look at the picture (#2) where you can see the cracking in the tread groove and that looks to be where the tire was severely deformed due to the steel belt separation. The grooves to the right, away from the deformation appear to be crack free. I think that the deformation caused the cracks in the groove.
No potholes and I haven't hit anything with the tires. The roads are terrible in the middle of Houston but I rarely drive there as I live about 1 hr north of the center of the city. My roads are much better up here.
I can tell you that running tire pressure monitors on my truck that the pressure can change 5 psi just sitting when in the sun here in the high desert, I have seen them climb almost 10 psi driving, so 70-75 psi seems a little high to me unless your truck has a heavy load all the time. I don't know if that would contribute to your issue but it seems your running them just below max loaded pressure which is probably harder on them and would make for a rougher ride without a load.
Load Range: E
Max Pressure: 80psi cold
Alignment: never since I bought the truck in Jan 2012. It has always had a very slight pull to the right. I do my own front end alignments on my cars but this truck is very different from what I'm used to.
Dampers: GABRIEL G63622 Nothing special, installed late January 2022
Springs: Factory springs from 2001
Mark
As for alignments on these, if you have the equipment and knowledge, which sounds like you do, they are really not that different. Camber is a bushing on the upper ball joint and Caster is springs mount angles(on 4wd, not sure on the 2wd) and toe is the tie rods. Pretty simple really and based on your slight pull your toe is probably slightly off. That all being said your tire separation issue should have nothing to do with your alignment.
The max pressure on the tire says 80psi cold. I do realize that the pressure is going to increase when the tire gets hot from driving or the sun hitting it. I usually run the front right tire at about 75psi cold and all the other tires at about 70psi cold. I run just a bit more pressure in the right front tire because the truck pulls slightly to the right and a bit more pressure seems to counteract that some. I never let the pressure get below 65psi cold on any of the tires even in the winter time. If they are that low, which a couple of them were last winter, I'd air them back up to my normal range. I check air pressure on my tires about every 4 months.
Okay. So it sounds like I should be running less air pressure than I've been running. What air pressure do you guys recommend?
The camber bushing has me a bit confused. It looks like it would take the appropiate one of these: MOOG K8972 Here is another that is 2 degrees: MEVOTECH MK8978
