1994 turbo
Old 01-20-2016, 05:37 PM
Rocketattack's Avatar
Rocketattack
Rocketattack is offline
1994 turbo
Is there a procedure to figure out if my wastegate is leaking? It only builds 7psi at WOT w/ or w/out a load. The rod is very hard to push. Never seen it move when under load and let off throttle. My truck is a 1994 f350 CC dually 7.3L factory turbo.
Old 01-20-2016, 06:38 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Should be a little higher, but about right, theyre set to approx 9psi. Search around, there is a write up on how to adjust it to get more boost.
Old 01-20-2016, 09:55 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
If, at WOT, you are smoking black, you need more air(and thus more boost). If you /aren't/, extra boost won't help. You need more fuel first.
Old 01-21-2016, 01:02 PM
Rocketattack
My original pump went on the fritz along time ago, it would roll the coal when WOT. I now have a '92 7.3 non turbo pump on it. I get better gas mileage and no black smoke as this pump does not pour fuel into engine.(I do still have and plan on getting OEM pump rebuilt and reinstalled.) I just dont hear any turbine whine or every see the vacuum diaphragm move the arm.
Old 01-21-2016, 07:51 PM
mroth2008's Avatar
mroth2008
mroth2008 is offline
MORE FUEL!!! Turn it up a flat or two, its okay to roll coal just back off the throttle and have a pyrometer, a little bit of extra fuel helps is spool up a lot faster. I always ran my truck with the pump maxed out throttle is just a fuel lever if its belching black smoke back off and if it ain't more throttle.
Old 01-21-2016, 08:26 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
To some extent, yes. Generally, with a turbo, you'll turn it up until you only get a light haze at maximum boost high in the revs. Any more than this is useless.
However, even at this point, you will need to pay attention when low in the revs, because you can easily overfuel it and create a lot of black smoke(and /less/ power).
It's all in the throttle.
Old 01-22-2016, 11:10 PM
Rocketattack
I'm not trying to get more power and less fuel mileage. Just wondering if i am loosing power from a pressure leak at the bypass valve.
Old 01-22-2016, 11:14 PM
hairyboxnoogle
If there is no smoke, then you are not missing any power. Turning up the pump wont necessarily give you worse mileage, just gives you more available fuel. Having a turbo with a stock pump seems pretty redundant to me.
Old 01-23-2016, 08:47 AM
snowdog79's Avatar
snowdog79
snowdog79 is offline
My right foot sets my fueling limit and it is monitored by my right rear view mirror. You, high tech.
diesel fanatic
08-07-2012 12:31 AM
jaluhn
02-17-2012 07:25 AM
tootall5764
02-16-2011 06:17 PM
royzell
01-08-2008 05:08 PM
92f250
09-01-2004 05:56 PM
Quick Reply: 1994 turbo
